replacing fan belt on '04 ram 2500
Old May 29, 2007 | 09:32 PM
soobieajax325's Avatar
soobieajax325
Default replacing fan belt on '04 ram 2500
i was wondering how you take off the serpentine belt on an '04 ram? it's the 2500 series with a/c and it's automatic. i've checked a few times already, but i still can't figure out how to remove or even loosen the thing. any help would be very much appreciated. thanks.
Old May 29, 2007 | 10:00 PM
JimmyDiablo's Avatar
JimmyDiablo
Default RE: replacing fan belt on '04 ram 2500
Have you climbed under it and checked for anything there? I am at work and can not get to my truck. Check under it might be something.
Old May 29, 2007 | 10:17 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
Most serpentine belts on newer vehicles use a tensionar pully system. One of the pullies that the belt is going around is on a spring loaded arm that keeps the tension tight. On my 07 Ram CTD the pully is on the lower left side, I'm not sure where it is on yours though. (when looking at the engine from the front bumper.) To get the belt off you need to push against the spring tension on the tensioner arm. Most tensioners allow you to use a 3/8" or 1/2" ratchet/breaker bar to use as a lever. There should be a square hole to put this in.
[align=left] [/align]
Old May 29, 2007 | 11:50 PM
sabersix's Avatar
sabersix
Here ya go.
http://www.sabersix.com/images/DriveBelt-5.9_Diesel.pdf
Old May 29, 2007 | 11:57 PM
JimmyDiablo
Your good.[sm=icon_ladiesman.gif]
Old May 30, 2007 | 03:17 AM
Kev_n_AZ's Avatar
Kev_n_AZ
sabersix
where were you when my belt went on the freeway 5 months ago???? forced that dang belt over the alt pulley when puttin it back on...tensioner was released (oh yea, had to replace the tensioner too...pulley siezed!!! ).
Old May 30, 2007 | 07:18 PM
soobieajax325
dammit!!! so i was putting my breaker bar in the wrong spot. thanks for the link. appreciate it
Old May 30, 2007 | 07:35 PM
Drew's Avatar
Drew
oh hell. . .that's getting linked to the FAQ
Old May 30, 2007 | 07:55 PM
Mayfair's Avatar
Mayfair
I was going to pick up a spare belt to have for an emergency, but they wanted almost 50 bucks for it. Is that how much they go for now?
