truck pull off...
Old May 31, 2007 | 11:48 PM
  #61
bksram3500's Avatar
bksram3500
Default RE: truck pull off...
I am going to make the ford to dodge switch tomorrow. no more power that my ford desiel has you should pull him with ease
Old Jun 1, 2007 | 12:38 AM
  #62
jakebrake's Avatar
jakebrake
All right drew, you wanna play, How about 400,000lbs constant pull
Old Jun 1, 2007 | 03:30 AM
  #63
rangerman's Avatar
rangerman
ORIGINAL: Mayfair
Don't forget to drape a tarp or something over the tow strap so that once you DO rip his rear off it won't come ripping through your back window !!!
I'm serious !!
Screw that, you need something way heavier than that, you will probably end up ripping his truck in half!!!
That would be awsome!!!
Old Jun 1, 2007 | 04:14 AM
  #64
finny's Avatar
finny
this is my favorite http://www.youtube.com/watch?v=Fmofb...ted&search=
hahahah
Old Jun 1, 2007 | 05:01 AM
  #65
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: jimmydaleo
ORIGINAL: Mayfair
I'm serious !!
Very good advise. You can tie strap some 5-10 pound weights in various places of the strap. I would avoid using chain. a good 30,000or above strap would be best imo.
Do Not Tie wieghts to the strap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If the strap breakes on his side of the weights the strap will sling shot them like cannon ***** at you.
Use blankets a tarps (not the plastic ones)
It is not wieght that slows a broken strap down but wind resistance of the blankets and tarps.
Old Jun 4, 2007 | 10:32 PM
  #66
JimmyDiablo's Avatar
JimmyDiablo
How did it go?
Old Jun 4, 2007 | 10:39 PM
  #67
Drew's Avatar
Drew
hopefully the ford broke a driveshaft. . . . . . . . .
Old Jun 4, 2007 | 10:47 PM
  #68
jakebrake's Avatar
jakebrake
Hopefully it broke at the diff and before he could shut her down, tore up the undercarraige.
Old Jun 4, 2007 | 10:51 PM
  #69
Drew's Avatar
Drew
there used to be a bar on the noth end of Atlanta where pull off's were done nightly in the parking lot. . .worse part about it they tied axel to axel
Old Jun 4, 2007 | 10:54 PM
  #70
jakebrake's Avatar
jakebrake
How many broken centerbolts?
