Clearance lights
Old May 31, 2007 | 01:46 AM
josh2500's Avatar
josh2500
Default Clearance lights
Does anyone elses clearance lights leak? Mine have been leaking for a few months now. The water is coming out of the plastic peace that the sunviser snaps in. Anyways, does anyone know a good place to get some aftermarket ones or recommend a specific kind. I am about to take the truck in to get my front pinion seal replaced, so i guess i could go ahead and see if the warranty would take care of the lights as well.
Old May 31, 2007 | 01:53 AM
FroneDaddy's Avatar
FroneDaddy
Default RE: Clearance lights
You should fill out your signature line with the specifics of your truck so we can better answer your question...............
Old May 31, 2007 | 02:00 AM
nickcoletti's Avatar
nickcoletti
i have that same problem! ive been meaning to post but always forget because it does not rain everyday. it comes thru my passenger side visor swivel. it drips about every 30sec. when its raining. its got to be a factory problem if i have the same problem! i thought about maybe sealing the clearence lights w/ sylicone?!?!
Old May 31, 2007 | 02:10 AM
josh2500's Avatar
josh2500
Yea i thought about that to, but i think my screw holes might be leaking. I looked at the gaskets and they arent dried up and the surface under the lights are clean so im not sure where the water is coming from. Hopefully they will give me some new ones and if not i will pick up some aftermarket ones and just seal the gasket with some silicone. I was thinking about getting the clear lights anyways. I think they look pretty cool.
Old May 31, 2007 | 02:14 AM
jskepler_03's Avatar
jskepler_03
just fixed this problem last week, except my water was running down the a pillar and soaking the carpet, took me awhile, took all the carpet out and was looking for a hole in the floor, but surprise was the cab lights, just lifted em off and coated the underside with silicone, sure as heck shouldnt leak anymore
Old May 31, 2007 | 02:20 AM
josh2500's Avatar
josh2500
Yea, thatsprobably what i am going to do. If it keeps leaking i will just get some new ones.
Thanks
Old May 31, 2007 | 02:21 AM
Bigriver's Avatar
Bigriver
I had a windshield replaced and I think that the installers may have put pressure on mine and cracked them. I have looked closely and have seen small cracks near the holes for the mounting screws. Yes, mine leaks at the driver's visor clip also. I bought a few replacements and have yet to install them. Seems to be an inheirant problem with our trucks. Just wondering too, are there any better designed aftermarket replacements or an improvement on sealing these suckers?
Old May 31, 2007 | 09:31 AM
sabersix's Avatar
sabersix
There is a Technical Service Bulletin on this problem.
TSB 23-009-06
