Most important gauges
Old May 31, 2007 | 10:11 PM
cumminalong's Avatar
cumminalong
Default RE: Most important gauges
It's built into the my Attitude monitor.
Old Jun 1, 2007 | 12:12 AM
DieselDemon's Avatar
DieselDemon
I don't think my TC can slip.
That's my typing for 2day.
Old Jun 1, 2007 | 01:25 AM
02cummins's Avatar
02cummins
tranny slip gauge ? never heard of one either...i wonder how that works.
Old Jun 1, 2007 | 02:45 AM
finny's Avatar
finny
my local shop suggested boost, egt, and transmission temp.
Old Jun 1, 2007 | 02:53 AM
joepascoe19's Avatar
joepascoe19
ive got the quadzilla comander on order it has a pod that still uses the grab handel ill take some pics when i get it installed and it has every gague built into one
Old Jun 1, 2007 | 03:33 AM
SpLaT's Avatar
SpLaT
I just ordered pyro, boost and tranny temp and an "indash" mount from dieselmanor.com, the boost gauge reads 0 to 60psi (for future mods ) Also ordered up a electric fuel gauge with a "steering coloum" mount. the 3 gauge set ran just under $300.00USd. The three gauge set comes with all necessary bits for complete install, along with colour picture type of instructions .
Old Jun 1, 2007 | 09:58 AM
cumminalong
ORIGINAL: 02cummins
Basically, it's measuring the input RPM's from the engine and then the RPM of the tranny after the TC.
When the TC locks, it should be a 1:1 drive ratio there. If it's not, it displays a percentage of slip on the screen.
Example:
Let's say that you we turning 2000RPM at the crank and 2000 RPM at the tranny input shaft. This, obviously is 0% slip.
Now, let's say at 2000 RPM (crank), you had 1980 RPM at the input shaft. You have 1% slip.
The most I've seen is 38%. This happens when the TC unlocks to go from 3rd to 4th in T/H mode. It's not actually slipping, the computer stills sees it as locked until it fully disengages.
The most I've had it slip when it was actually locked is about 9%. That was with the Juice on Level 4 and I hammered it from a stop.
It'll do it to if I have the power crank up on the highway and go from no or little skinny pedal and then stomp on it.
Old Jun 1, 2007 | 11:48 AM
Drew's Avatar
Drew
I wonderhow much myclutch is slipping with the TST on 8/8
Old Jun 30, 2007 | 12:18 PM
Prosport Gauges's Avatar
Prosport Gauges
Be sure to check out our all new website for all your gauge needs
www.prosportgauges.com
