AIR CONDITIONER..........sucks
Old Jun 1, 2007 | 11:28 AM
abby4000's Avatar
abby4000
Default AIR CONDITIONER..........sucks
Hello ALl
Anyone else think that the air in these trucks do not work great??? Maybe problem with mine but it is almost blowing warm air out
Any suggestions Thank YOu
Old Jun 1, 2007 | 11:37 AM
handymanherb's Avatar
handymanherb
Default RE: AIR CONDITIONER..........sucks
Mine works fine, you might have a problem, but since we don't know what year CTD you have it's harder to comment
Old Jun 1, 2007 | 01:17 PM
abby4000's Avatar
abby4000
oh yes sorry, that may help
Its an 06 3500 CTD.
Old Jun 1, 2007 | 01:41 PM
Joel_MD's Avatar
Joel_MD
I was just thinking the same thing about my new 2007. It's beginning to get warm here in Maryland, and the a/c in my new Dodge doesn't seem as good as the one in my 11-yr old Chevy 2500. Maybe Dodge uses smaller a/c compressors to help MPG? Does anybody know for sure? When it's really hot I put my a/cin the recirculating mode, which helps a little.
Old Jun 1, 2007 | 02:13 PM
Drew's Avatar
Drew
one thing I have noticed look where the fan is. . .then look where the A/C condensor is. . .theres alot of area and things between the two. so much so the condensor doesnt get much air flow.
if there was room, or you are feeling ambitious, you could always install an electric fan on the front of the condensor, that would help.
Old Jun 1, 2007 | 06:47 PM
abby4000's Avatar
abby4000
wow that is very surprising, I would have figured Dodge would have thought of that, my old ford was like a meat locker.
Thanks for the replys guys
Old Jun 1, 2007 | 07:30 PM
NickBeek's Avatar
NickBeek
Abby,
I have had the same issue with mine when idling. I took it back the week after I bought it and had them take a look at it. They evacuated the system and recharged it to specs. It was a couple oz short from the factory. Last couple days it has been 88 - 91 here in SC I have been getting 45 degree air from the vent while moving and about 55 - 60 when I stop. I have noticed that it takes some continuous driving to get it to pull down though. I am thinking of installing a coolant bypass valve on the heater core to keep the heat out of the air exchange box. My '04 Ford had one from the factory that only worked during recirc mode and I rerouted the vaccum lines to make it work while in any vent mode. That helped it some.
Does anyone know of any good reason not to do bypass the heater core in these trucks? If not I'm gonna find a solenoid valve to do it and report back. The big rig trucks have a manual valve they shut off during the summer months.
Old Jun 1, 2007 | 07:42 PM
Mayfair's Avatar
Mayfair
I know Diesel Demon did some pretty crafty stuff with am electric fan in order to get his AC as cool as possible.
Check out his auxilary fan ....
[IMG]local://upfiles/42139/7C58753656DC4337B973A06A85D61D5A.jpg[/IMG]
Old Jun 2, 2007 | 12:58 AM
moconst's Avatar
moconst
I have an 06 and the A/C gets frigid cold (knock on wood). Maybe there is a problem with your system.
Old Jun 2, 2007 | 03:20 AM
plasterman's Avatar
plasterman
I had my 04 that sucked and my 05 as well took the 05 back they recharged it but I couldn't tell the diff. Mine seems to be colder on the drivers side vents .... I dono but I put up with it for the CTD
