I reused diff cover gasket....is that good
Old Jun 4, 2007 | 03:04 AM
sallyman1's Avatar
sallyman1
Default I reused diff cover gasket....is that good
Is it ok to reuse the gasket from the diff covers. I changed the rear diff today and the old gasket looked good. I just cleaned surfaces good and added a little rtv silicone to one side of gasket and voila....no leaks yet. but im wondering becuase i read of most using just the silicone.(no gasket)
Old Jun 4, 2007 | 03:06 AM
speakle's Avatar
speakle
Default RE: I reused diff cover gasket....is that good
In my opinion it is NEVER ok to reuse a gasket unless its an emergency and you plan on replacing it or it doesnt matter if that particular part leaks.
Old Jun 4, 2007 | 03:14 AM
moconst's Avatar
moconst
Never reuse gaskets, Its like reusing a rubber. Might work for awhile, but could fail later
Old Jun 4, 2007 | 03:19 AM
speakle's Avatar
speakle
Nice analogy.
Old Jun 4, 2007 | 10:08 AM
cumminalong's Avatar
cumminalong
Don't sweat it, you're good. The gasket on the AAM axles is designed to be reused. It's not a disposable type like the ones of old.
And, you're not suppossed to use RTV with it.
Just clean the surfaces and re-install.
Here, read this.....
https://dodgeforum.com/m_771515/tm.htm
Old Jun 4, 2007 | 02:24 PM
Kev_n_AZ's Avatar
Kev_n_AZ
the local dodge stealer here uses a silicone based gasket crap when they do your dif's. no rubber, cork, or an other form of prefab gaskets are used. hell i even got a free tube from then too!!!
MOPAR axle-rtv (silicone rtv)
part # 050113477AA
ms-gf46
Old Jun 4, 2007 | 06:08 PM
cumminalong
ORIGINAL: bajafun
On the trucks with D60 axles, then yes, you need the RTV as they don't have reusable gaskets.
The AAM axles have a reuseable one.
Old Jun 4, 2007 | 06:10 PM
BLEWMONEY's Avatar
BLEWMONEY
the difference between the rears with and without a gasket, 8-1/4 and 9-1/4 use sealer 10.5 and 11.5 use a gasket. and as per the dodge service manual the gasket is ment to be used 3 to 4 times. if its over tightened it will need replaced otherwise use it again.
