New Dodge Diesel Owner
Old Jun 14, 2007 | 05:27 PM
foxtrotnem's Avatar
foxtrotnem
Default New Dodge Diesel Owner
hi, i just bought a 2003 1 ton dodge diesel...it has a 5 speed tranny, 2wd, no duallys...i pull my horse trailer with it. i have never owned a diesel before. i am loving this truck so far. i have a few questions that yall will probably think is stupid but i'm getting tons of different answers from people here at work....what kind of oil is preferrable to use (synthetic or rotella) and how often do you change it? also, talk to me about "speed shifting". is that when you don't push in the clutch to shift gears? isn't this bad for the transmission? i'd like to get this truck completely serviced since i bought it used with 119K miles on it. what fluids should i have flushed and changed during the servicing? also, do you put any additives in the fuel at any time for any reason? thanks for your patience....
Old Jun 14, 2007 | 05:38 PM
steve05ram360's Avatar
steve05ram360
Default RE: New Dodge Diesel Owner
welcome to DF!
oil is a preference thing... I use Amsoil and am very happy with it. Speed shifting sounds like your just moving the clutch pedal & shifter quick to minimize the boost loss while your between gears.
On the fuel, there is a Drews Brew tread at the top of the forum which will help out alot. I personally use 16 oz of Power Service Diesel & 16 oz of 2 stroke oil and am happy with it. helps to keep the injectors clean and there is a slight boost in mileage (~1.0 mpg).
As for the fluids, I'd change all of them so you know where your at with them.
there is a thread at the top called diesel rollcall, feel free to stop by and give yourself an intro...
Old Jun 14, 2007 | 05:42 PM
Kev_n_AZ's Avatar
Kev_n_AZ
WELCOME!
sharx ram's Avatar
sharx ram
Welcome to the family [8D]
Old Jun 14, 2007 | 06:12 PM
foxtrotnem's Avatar
foxtrotnem
do you put the PSD in every time you fuel up and do you put the 2 stroke oil in the with the fuel every time or just some times?
i will go check out the other threads you mentioned...
thanks for the other welcomes as well!!
Old Jun 14, 2007 | 06:21 PM
Mayfair's Avatar
Mayfair
[sm=ttiwwp.gif]
[sm=welcomesign.gif]
I change my oil every 5000 and I use Rotella. I have ever since it was new.
Right now I'm adding 1oz of 2 stroke oil to my fuel every time I fill up just to make sure things are lubed
I'd change at least your oil, and diff fluid as well as your air filter right now. Test your coolant, it may be just fine.
Best of luck with it and welcome aboard brotha !!
Old Jun 14, 2007 | 06:29 PM
foxtrotnem's Avatar
foxtrotnem
mayfair...thanks for the info....only thing is i'm a sista!!!
Old Jun 14, 2007 | 06:30 PM
steve05ram360
I do the 16/16 every fillup of minimum 30~32 gallons of fuel.
Old Jun 14, 2007 | 06:35 PM
Mayfair's Avatar
Mayfair
ORIGINAL: foxtrotnem
Well then DEFINATELY commence with the pixx girlfren!!!!!
Old Jun 14, 2007 | 06:40 PM
foxtrotnem's Avatar
foxtrotnem
ok, i'll get some pix tonite when i get home...don't tell the HMFIC i'm surfin about trux on company time!!!
