not for the faint at heart !! >>>
#21
RE: not for the faint at heart !! >>>
ORIGINAL: Drew
I think your on the right track. . .see what is more cost effective. I'm just wondering if the 5.9 blockhas enough meatbe bored out to 6.7L spec. get ahold of some 6.7L pistons and ceramic coat the thing.
#22
#24
trying to push it to a 6.7 would be a headache... I say get the cylinders bored to the next size up, coated pistons and be done with it. put the rest of the bux into the head & firinging the block (if needed) & head. Get a new set of cams, port & polish the head and the SS valves he mentioned. mount up that new turbo that is sitting in the garage and make that puppy sing again...
#25
Aren't there any local machine shops that you could take the block to to have the work done without having to ship it anywhwere? Gas, diesel, whatever, boring a block is boring a block, it's all the same isn't it? I'd be asking around for a good local machine shop and call it a day. Send the extra cash to The MAYFAIR Fund - Philadelphia PA
#27
mopar98 - you really have to be careful running meth. Water only is what I've seen to be the trick. If your motor is really built then yes, meth may work for you. Someone coorect me if I'm off here but, meth will increase pressure and if you're already running a pressure box, you're asking for trouble.
Mayfair - I live in a 4 stop light town. McDonalds is a 30 minute drive down the mountain so, it's a good suggestion but, there's literally nothing for 2 hrs in any direction around here. It's kinda a Vail CO. type area where all the rich Atlantans build their second homes.
Well I'm getting some where with the truck. The head is going out tomorrow. It's going to be ported/polished, new permanent valve seats install along with larger SS valves, machined for fire rings, new heavy duty springs to accommodate the new cam shaft.
The block will be going out in a week to be bored for some new Arias pistons & rods. I sent out my injectors today to be honed for 125hp and my rail also went out today to get the " wild bore " !!
Obviously it going to take long than I had hoped to get back together but, once it is... vvvrrrrroooommm !
#28
#29
ORIGINAL: steve05ram360
what is each service going to cost? and how much are the pistons & rods?
#30
