Mounting a Flashlight charger in cab?
Old Jun 17, 2007 | 12:38 PM
TrpD345's Avatar
TrpD345
Default Mounting a Flashlight charger in cab?
I want to mount 2 Stinger flashlight chargers in the cab of my 2005 2500. Where should I tap in for the hot wire? I only want them to charge when the switch is on. One will be mounted between the door and the drivers seat on the floor board and the other will be just above my right knee. Thanks!
Old Jun 17, 2007 | 01:56 PM
jakebrake's Avatar
jakebrake
Default RE: Mounting a Flashlight charger in cab?
there are several spots on the fuse block that you can use. Empty sockets for future add ons. All you would need would be to get a couple of terminals to plug into the fuse block. I love my stinger, I got a charger that will charge an extra bat along with the flashlight
Old Jun 17, 2007 | 04:27 PM
TrpD345's Avatar
TrpD345
Are you talking about the fuse black under the hood? Thanks for the help!
Old Jun 17, 2007 | 05:56 PM
jakebrake's Avatar
jakebrake
There should be one under the dash somewhere. Not sure exactly where on the gen3s
Old Jun 17, 2007 | 06:15 PM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: TrpD345
The right hand power outlet on your dash goes on and off with the key you can tap into the wire going to it, that what I did for my radar detector.
Old Jun 17, 2007 | 07:52 PM
beachmstr's Avatar
beachmstr
The power outlet goes on and off? Mine stays on when the truck is off. My 01 did the same thing. Are you sure your not thinking of the cigarette lighter adapter.
Old Jun 17, 2007 | 08:32 PM
Captain Squalus
ORIGINAL: beachmstr
My error the left one is the one that goes on an off with the key the right one stays hot and the one in the console stays hot.
Old Jun 17, 2007 | 09:41 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
ORIGINAL: beachmstr
My truck is the same way
