P1693 & P1687
Old Jun 20, 2007 | 01:28 AM
CowboyBob's Avatar
CowboyBob
Default P1693 & P1687
I just installed my new Quadzilla Commander and after the install when I hooked the batteries back up, the check engine light was on. When I did the 3 time ignition trick I got P1693 and P1687. The P1687 makes since because I had to pull the cluster fuse to wire up the commander. I don't know what the 1693 means. Truck runs fine so I cleared the codes and drove it for a while.
Old Jun 20, 2007 | 10:07 AM
Drew's Avatar
Drew
Default RE: P1693 & P1687
P1693. . .Turbo Charge Control Circuit Malfunction
sounds like the MAP sensor. . .if it comes back might need to clean it or replace it.
Old Jun 20, 2007 | 11:14 AM
CowboyBob's Avatar
CowboyBob
Ok makes sense. I had to pull the map sensor connector and hook a wire tap to the harness. If it comes back, then I'll worry about it. I drove the truck about 40 miles on the interstate today with no codes.
Old Aug 23, 2015 | 02:45 AM
Connie Melissa Kiernan's Avatar
Default Help pulled cluster fuse now check engine light is on and getting codes p1693 p1687
I tried clearing my codes but only the check engine light went off why how do i know that the codes are only from me pulling my cluster fuse????
Last edited by Connie Melissa Kiernan; Aug 23, 2015 at 02:46 AM. Reason: For got to write something
Old Aug 23, 2015 | 09:28 AM
HammerZ71's Avatar
HammerZ71
If the CEL doesn't come back it's almost certainly from pulling the fuse...
