NV5600 Question
Old Jun 20, 2007 | 01:34 AM
CowboyBob's Avatar
CowboyBob
Default NV5600 Question
Does the NV5600 have a test port for a temp sensor? Is this even worth fooling with on a manual tranny? My new quadzilla commander has a tranny temp sensor port, but I can't seem to find anyplace to hook it up. Does anyone out there have an NV5600 with a temp sensor on it?
Old Jun 20, 2007 | 02:54 AM
jakebrake's Avatar
jakebrake
Default RE: NV5600 Question
Not sure on the port, but you can always pick up a pto cover plate and put a sensor in it (weld an insert to thread the sensor in), then swap covers when it's time to service the trans.
Old Jun 20, 2007 | 10:10 AM
Drew's Avatar
Drew
ORIGINAL: jakebrake
that would be the only way.
Old Jun 20, 2007 | 11:12 AM
CowboyBob's Avatar
CowboyBob
Is it even worth monitoring the temp on a manual tranny????
Old Jun 20, 2007 | 01:20 PM
Drew's Avatar
Drew
for the 5600. . .I wouldnt worry about it unless you were pulling big loads, then the coolers that go in place of the PTO covers would be sufficient.
Old Jun 21, 2007 | 11:19 AM
CowboyBob's Avatar
CowboyBob
That's pretty much what Quadzilla told me. They suggested monitoring the oil temp instead. I didn't know there was a test port on the filter housing. I'm gonna hook it up this weekend.
Old Jun 22, 2007 | 04:36 AM
R0oster31's Avatar
R0oster31
Yea, I would wait on swapping that pto cover too. I just tore apart my tranny and that stuff isn't cheap.
Old Jun 23, 2007 | 02:25 PM
CowboyBob's Avatar
CowboyBob
I put it on the oil test port on the oil filter housing. Works great! You can even change the heading on the readout from "Transmission" to "Oil Temp".
