changing serpintine belt on 04
Old Jun 20, 2007 | 04:53 PM
towingRam's Avatar
towingRam
Default changing serpintine belt on 04
Hello,
I am looking for help with instructions or diagram for changing the serpintine belt on my 2004 1/2, 3/4 ton 4x4 diesel.
Thanks,
Old Jun 20, 2007 | 05:01 PM
Drew's Avatar
Drew
Default RE: changing serpintine belt on 04
Ive seen a pic of it around here somewhere. just to let you know it is a pain, but do-able.
Old Jun 20, 2007 | 05:03 PM
steve05ram360's Avatar
steve05ram360
welcome to DF... not having done it yet on mine, cant say much about it other than you should have a tenisoner with a bolt on it that will allow you to put a socket or wrench to use as leverage to get the belt off... my 2000 5.9 gasser had that setup so i'd assume the diesels should be the same.
Old Jun 20, 2007 | 05:07 PM
towingRam's Avatar
towingRam
Thanks, any chance you can point me in the right direction to find it?
Old Jun 20, 2007 | 05:22 PM
Drew's Avatar
Drew
try this out
http://www.dodgeram.org/tech/dsl/coo...ys/fanbelt.htm
Old Jun 20, 2007 | 05:44 PM
towingRam's Avatar
towingRam
That should help alot. Thanks!!
Old Jun 20, 2007 | 06:44 PM
sabersix's Avatar
sabersix
Here is the page from the 2004 Dodge Service Manual.
Link
Old Jun 20, 2007 | 10:38 PM
Watermelon's Avatar
Watermelon
If you have a HOT temper ,dont do it!!! Me and my boy changed mine the other day on my 04 CTD and I gottta tell you ,its a booger to do by yourself. After you get the old belt off, make sure someone is on the topside to help. I had to get mine threaded over the tentioner and then got my son to put over the alternator while I pulled slack on the tentioner. Its so dang tight in there its almost impossible to do the job by yourself. The job would be easier if we would have had a longer ratchet to hold the tentioner (More leverage)
Old Jun 20, 2007 | 11:19 PM
NickBeek's Avatar
NickBeek
And whatever you do, don't get your finger between the belt and any pulleys. Cause that will be when the wrench slips and it hurts like a mother.
