Help - - throwing codes!!
Old Jun 23, 2007 | 02:40 AM
YJBrian91's Avatar
YJBrian91
Default Help - - throwing codes!!
Check engine light came on today! The truck threw codes P2121 and P2122. Can anyone help me with this?
Old Jun 23, 2007 | 02:52 AM
jakebrake's Avatar
jakebrake
Default RE: Help - - throwing codes!!
Sorry, my list of codes stops at P1900. hopefully someone else will chime in
sallyman1's Avatar
sallyman1
how are you catching the codes? are you using a baseball glove?
Old Jun 23, 2007 | 02:55 AM
jakebrake's Avatar
jakebrake
Not sure if that was helpful, but it was funny[&:]
Old Jun 23, 2007 | 03:14 AM
master tech's Avatar
master tech
Site Moderator & Tech
code 2121 App voltage do not agree with Idle valitdation signal and 2122 Low volts at App sensor. If you would the dignostic sheet for both codes, send me an e-mail.
Old Jun 23, 2007 | 05:04 AM
Captain Squalus's Avatar
Captain Squalus
P2121 Throttle/Pedal Pos Sens/Switch D Circ Range/Perf
P2122 Throttle/Pedal Pos Sens/Switch D Circ Low Input
Old Jun 24, 2007 | 01:30 AM
YJBrian91's Avatar
YJBrian91
ha! ha! been told that it is accelerator pedal position sensor. I think it is only available through the stealership! $599.00!!!
Does anyone know if it is available anywhere else? Thanks for the help fellas!
