ISSPRO Gauge Kits
Old Jun 23, 2007 | 03:37 AM
cesibley's Avatar
cesibley
Default ISSPRO Gauge Kits
Does anyone have an opinion on the ISSPRO gauge kits that Dieselmanor sells? The prospect of buying a all in one kit appeals to me.
Does anyone know if the A pillar mount requires cutting the original cover like the Autometer ones?
I there any reason I should get a trans temp gauge for a 6 speed manual, or is that just a auto trans thing.
Does anyone else have a recommendation for a kit, and where to buy?
Getting ready to pull the trigger...
Thanks,
Curt.
Old Jun 23, 2007 | 03:48 AM
bksram3500's Avatar
bksram3500
Default RE: ISSPRO Gauge Kits
This post could answer a lot of you questions
https://dodgeforum.com/m_855259/tm.htm
Welcome to DF
Old Jun 23, 2007 | 04:48 PM
cmnspwr's Avatar
cmnspwr
I bought my Isspro's from DieselManor. Everything I needed came with the kit. I suggest filling out your signature so we know what truck you have. If you have a 3rd gen, you just remove the two screws and pull off the old pillar. The new pillar is held on by just one screw. I don't think that a trans temp gauge on a 6spd is necessary.
Old Jun 23, 2007 | 04:57 PM
cesibley's Avatar
cesibley
Good point! My truck isa 2002 3500 CTD with 6 Speed
Curt.
Old Jun 23, 2007 | 06:00 PM
CamperAndy's Avatar
CamperAndy
Get the option with the fuel pressure gauge. You get everything you need except for the fittings and hose to go from your filter to the isolator. I did not want to spend the extra 50 on the diesel manor connection kit and purchased 3 feet of 5/16 id fuel hose and a 5/16 tee and spliced into the fuel line going from the filter to the injector pump.
Works and looks great.
Old Jun 23, 2007 | 06:54 PM
firemansdodge's Avatar
firemansdodge
I purchased the Isspro Guages (pyro,tranny,boost) andA pillar podmount fromDiesel Manor. I think they match one of the best out there w/ your cluster guages. You do not need a tranny guage for the manuel. like posted above. Get a fuel pressure guage w/ the boost & pyro. When get a chance I will get you a pic of my set up.
Old Jun 24, 2007 | 12:16 AM
cesibley's Avatar
cesibley
Getting a fuel pressure gauge sounds like a good idea. I think I'll call Monday and place the order.
How hard is it to run the boost and fuel pressure lines through the fire wall?
Curt.
Old Jun 24, 2007 | 02:18 AM
cmnspwr's Avatar
cmnspwr
I'm not sure about the 2nd gens but on the 3rd gen trucks, there is a hole just behind the brake pedal to run all your wires.
