Boost fooler, Should I get one?
Old Jun 26, 2007 | 02:55 AM
moconst's Avatar
moconst
Default Boost fooler, Should I get one?
Just wonderin if anyone has any thoughts on the boost foolers? Can someone explain how they work? And do you benefit from using them?
Old Jun 26, 2007 | 03:06 AM
speakle's Avatar
speakle
Default RE: Boost fooler, Should I get one?
They scare me.
moconst's Avatar
moconst
why? What exactly do they do?
Old Jun 26, 2007 | 03:08 AM
speakle's Avatar
speakle
They allow the turbo to build more boost by keep the wastegate closed. I would be afraid something would blow up.
Old Jun 26, 2007 | 03:22 AM
moconst's Avatar
moconst
So the arent very safe? Do they cause problems often? Sorry for all the questions, just curious bout them
Old Jun 26, 2007 | 03:24 AM
jakebrake's Avatar
jakebrake
There are 2 types of boost foolers. One just caps the signal so the ecm will only see up to that point, from then on the ecm will read steady boost as the fooler hides the extra. This is the type I would recommend. The other type hides part off the signal throughout the whole range so the ecm is seeing less boost than actual through the whole range.
speakle's Avatar
speakle
I honestly havent read about anyone having an issue with them but I wouldnt put on on my truck. Boost levels get up to 40psi with my truck set to stock, I am fine with that.
Old Jun 26, 2007 | 03:27 AM
moconst's Avatar
moconst
The highest ive seen on my truck is 25, What should the boost run normally? Isnt 40 high? Or maybe I drive to slow?
Old Jun 26, 2007 | 03:31 AM
speakle's Avatar
speakle
Thats odd, we have the same truck..I think. Typically I dont see over 20 but if I really get on it I hit 38-39. Moderatley hard accell is about 30-35. This freaked me out at first so I turned the edge to stock and I still hit 39psi.
Old Jun 26, 2007 | 03:39 AM
moconst's Avatar
moconst
Ill pay att to mine tomm and get some real numbers. see how we compare. Thanks for your patience and help
