Pyrometer, Boost Limits
Just had guages installed on my 2007 Ram 3500 with 6.7 diesel and automatic. We use the Dodge for pulling our 14,500 pound 5th wheel. Due to weight we want to make sure we don't exceed maximums and due damageto the engine or transmission. Therefore, what would be safe limits for Transmission temperature, Pyrometer reading (sensor is mounted after the turbo), and boost reading?
Thank you for any help.
Jim
Jim
RE: Pyrometer, Boost Limits
the wastegate will keep things below 35#. I'm not posative if the 6.7's gave higher stock bost numbers, but for any ride 35# is alot of pressure. you would probably see no more than 20-25 with some spikes to 30.
pyro, 900-1000 is as high as I would take it for any length of time. pre turbo numbers can go up to 1350 before you need to be concerned.
