Anyone else have creaky leaf springs?
Actually, I can't remeber if the spring pin bushings and shackle bushings are rubber or not. I'll have to crawl under there and look tomarrow. I've never changed them, so I think they are rubber.
I think there is a rubber one at the top where the bolt goes through the busshing. although there is a cheeper fix
Turn up the radio.. / remove silencer ring and hit the gass./ install an aero and hit the gas again./ pester a ford and hit the gas / you get the picture
I dont hear it when I am in the truck only when I am getting in an dout of the bed or hooking or unhooking my trailer. As for the knock, that just doesnt sound good. I will look into this more tomorrow and will update.
Ya
That knock doesnt sound good to me either.. might be a bad bushing from the factory. ask the neibors to get in the back and bounce it while you look under at the leaf connections ill bet you will find something there
As the post above. Try spraying the bolts w/ WD40. I had the same problem w/my nerf bars where they bolted up underneath the truck. I sprayed the bolts w/ WD40and noise gone. I know it'sdifferent from the rear springs, but same concept. Remember WD40 is like duct tape. It fixes everything.
