VP-44
Old Jul 5, 2007 | 02:53 PM
racevoodoo's Avatar
racevoodoo
Default VP-44
My '01 has about 65K on it now. I am working on my 4th lift pump and my third injector pump. All of these were replaced under warranty. I have no doubt the injector pump will fail sooner or later. My question is this: is there an aftermarket replacement or anything for this? I see no future in spending good money on a pump that is just going to fail again. So why bother with a factory pump if there is something else available. Thanks.
Old Jul 5, 2007 | 03:25 PM
Drew's Avatar
Drew
Default RE: VP-44
nope. . .even a rebuilt VP44 will still have the same issue. the main problem is the electric lift pump. get something better than stock and your problems will go away.
Old Jul 5, 2007 | 03:28 PM
CowboyBob's Avatar
CowboyBob
Default RE: VP-44
A FASS lift pump should solve your problems. The VP44 will last a long time as long as you keep a good steady supply of diesel fuel running through it. I have 170k on my original VP44.
Old Jul 5, 2007 | 03:47 PM
Silverline's Avatar
Silverline
Default RE: VP-44
Changing the factory lift pump will help out a whole lot...they fail pretty easy...a FASS from Geno's runs about $430 or so
