Got stuck bad
RE: Got stuck bad
I have a sunroof in teh truck, but in the heat I am in (Phoneix Az) the sunroof stays closed. The mini van does have remote start and a t.v. of course at the end of the night it is still a mini van. I should try and take that off roading so I can restrict myself from that and get my truck back. Hmmmmm sounds good to me.
RE: Got stuck bad
I remember putting my truck in some sand out behind the national guard post here,,, the front endof the truck hit the sand and sank to the sound of,, "ummmpphh". I quickly backed out since I still have stock tires on it. I actually get more race time in on the expressway here than I do off roadin.
RE: Got stuck bad
Hello is this the Mr. obvious show,
I'm a long time listener and first time caller
Heavy truck plus sand never has a good ending does it?
Most guys I know that go up to the dunes in Michigan use buggies, yodas,and jeeps with wide tires .
I don't know much about driving on the sand
So other than tires and a locker what could you do Jimmy to move out there better?
RE: Got stuck bad
I've been close to stuck once. That field was a little softer than I thought. Was able to work it out of the mud before it sank too far. Them stock tires kept it from digging. If you do air down tires, just becareful, that's a lot of weight up front and could easily pull the tire off the bead if you get traction.
RE: Got stuck bad
O.k I 'll share.
I got stuck once when I was coming home from school in the winter.
I turned into our drive way and I stopped and waited for the garage door to come up.
My old 2 wheel Ford wouldn't move at all. I was just spinnin away on the ice.
It was embarassing , I actually had the speedo showing 40 mph and couldn't move.
I thought surely I 'd take bite and go . Nope just sat there, I had to pulled by my dad in his Bronco
I was the joke at christmas that year.
