Can't remove steering damper
Old Jul 9, 2007 | 01:15 PM
BTCRUZ's Avatar
BTCRUZ
Default Can't remove steering damper
Hey guys, I have an 04 diesel 2500 and I put new shocks on it the other day (boy that was fun). I also have a new steering damper for it, but I can't get the bolt/stud out of the tierod. Is there a special trick for getting this out? I tried to ding it out with a hammer, but there's not enough room to get a good swing on it and I didn't want to bugger it up.
Old Jul 9, 2007 | 02:00 PM
bigmike's Avatar
bigmike
Default RE: Can't remove steering damper
That post is pressed in at the factory. You will need to buy/borrow a 2 or 3 prong puller to get it out. Just tighten down the puller and give it a couple smacks with a hammer. That is how i changed mine out.
Old Jul 9, 2007 | 04:14 PM
savage.basher's Avatar
savage.basher
I whacked mine out with a hammer. I know you can't get a good swing so instead use a real heavy hammer, that way you don't have to swing it so hard. If that dosen't work then do what Mike said and get a puller to push it out, it may be hard to get the arms of the puller to hold on to anything though. I would say best bet is alot of wd-40 and something heavy to whack it with.
Old Jul 9, 2007 | 07:58 PM
jh's Avatar
jh
I used a torch and heated it up. A couple light taps with a hammer and it popped right out no problem.
Old Jul 9, 2007 | 08:54 PM
CowboyBob's Avatar
CowboyBob
I broke a 2 prong fork trying to get mine out. A BFH did the trick for me. Also, if you wedge a piece of wood between the tie rod and the front axle, this will help keep the tie rod from flexing and absorbing the energy from the hammer.
Old Jul 9, 2007 | 11:36 PM
GFB's Avatar
GFB
3 arm puller. You can rent them at autozone for free. Just pay a deposit and it's refunded when you return it.
Old Jul 10, 2007 | 11:35 AM
Drew's Avatar
Drew
you broke a pickel fork getting yours out Bob. . .that thing must have been IN there.
Old Jul 10, 2007 | 12:41 PM
CowboyBob's Avatar
CowboyBob
It was in there good. I was ready to heat it up with a torch but luckily got it out.
