Anyone heard of a Hi/Lo tranny for a Dodge CTD?
Old Jul 9, 2007 | 05:57 PM
swilsone's Avatar
swilsone
Default Anyone heard of a Hi/Lo tranny for a Dodge CTD?
I was cruizin around EBay a while back and saw a Dodge CTD and the guy had a manual tranny with a Hi/Lo splitter style setup. Not sure if it was air actuated...I would imagine it was...the description didn't say much about the tranny and I can't findthe adotherwise I'd link to it. Anyone ever heard of this setup? The splitter could have been in the rear axle, I guess...
Old Jul 9, 2007 | 07:51 PM
jakebrake's Avatar
jakebrake
Default RE: Anyone heard of a Hi/Lo tranny for a Dodge CTD?
Probably just a gearvendors overdrive stuck on the back of the trans.
Old Jul 9, 2007 | 08:25 PM
NickBeek's Avatar
NickBeek
Two splitters out there Gear Vendors, and US Gear. I believe both are operated by electric, and cost dearly......
Old Jul 9, 2007 | 08:42 PM
dieselram's Avatar
dieselram
ORIGINAL: NickBeek
So it would have probably been a good buy if someone wanted that option.
Old Jul 9, 2007 | 08:52 PM
kg1687's Avatar
kg1687
They have something similar to like the browning which goes in bigger trucks, It's kind of like your transfer case 4 Lo and 4 Hi, Depending on which one you get you can have em mounted in various areas on your drivetrain, Some are electric, some pneumatic, and some are manual, very simple, just changes gearing, I'm thinking about putting one on my cummins so I can run higher speeds. Some are used to gear down your truck, I've seen them have half gears and such, to help with towing. I want mine to gear up so I can run with lower rpms in higher speeds like 85 running around 2200 sounds good. Then gear it back down when hauling.
Old Jul 10, 2007 | 02:32 PM
swilsone's Avatar
swilsone
Cool...thanks for the info guys!
Old Jul 10, 2007 | 05:58 PM
NickBeek's Avatar
NickBeek
ORIGINAL: kg1687
I went looking for the Browning, but could not find it on line. Do you have info on where to find it?
Old Jul 10, 2007 | 07:46 PM
steelhauler's Avatar
steelhauler
I have a gear vendor over drive behind my 6 spd. it is activated by a small electric switch mounted on shift tower. it cost around 3500 installed. it will not help your milage as much as you may hope.it is very handy when pulling a heavy load to be able to split down from 6th to 5 od etc. us gear also makes these in either over or under drive, if you get a good buy on one plan on building a new fuel tank as well.
