Transmission noise?
Old Jul 17, 2007 | 08:10 PM
pappyscrapster's Avatar
pappyscrapster
Default RE: Transmission noise?
What were you looking for in the battery terminals?
Old Jul 17, 2007 | 08:33 PM
Jr. Mechanic's Avatar
Jr. Mechanic
If you dont have a good ground you can have malfunctions in electrical systems, and just a hunch, but I think drew feels it is in the electrical system
Old Jul 17, 2007 | 08:54 PM
Drew's Avatar
Drew
ORIGINAL: Jr. Mechanic
for the most part. . .mayfair had a similar issue and it turned out to be the main ground did not have a good ground. thus he was having an erratic shift when the torque converter was locking up in O/D. plus this is a common issue from 98.5-00 trucks.
if that doesnt do it. . .when was the last time you changed the tranny fluid???
Old Jul 17, 2007 | 09:06 PM
pappyscrapster
Ahhh I get ya. ok so red blood cells changed along with 2 in-tranny componets, a gov/ electronic componet,( would not shift out of firsta)2 months ago, also just checked it again today(fluid) looks and smells ok,,
Ill let you know.
Old Jul 17, 2007 | 11:25 PM
jakebrake's Avatar
jakebrake
D-line timed? Hows the center bearing, slip yoke and ujoints? Maybe pull the diff cover and see what the gears look like.
Old Jul 18, 2007 | 02:23 PM
pappyscrapster
ORIGINAL: jakebrake
Not sure what D-line timing is? And to the best of my knowledge of those that you mentioned (thank you) they all seem to be ok, however I have yet to actually raise the rubber to test it all, w/out load. I will however look into freeing the rear wheels and testing. Ilook for you later Thanks,,
Pappy
Old Jul 18, 2007 | 02:27 PM
pappyscrapster
ORIGINAL: Drew
Well “bonk†seems to still be there, not as pronounced, however that could be due to me watching for it, you know how that goes..
At any rate, I'm open to whatever anyone cares to contribute [/i][/b]
Old Jul 18, 2007 | 02:35 PM
Mayfair's Avatar
Mayfair
ORIGINAL: pappyscrapster
I can throw this in for ya to help forget your tranny problems
Old Jul 18, 2007 | 02:40 PM
pappyscrapster
What tranny!!!! whew, better,,,,,,,
Old Jul 18, 2007 | 02:46 PM
aka_chewy's Avatar
aka_chewy
Just turn your radio up.....fixed a friend of mines Tranny for a while.(they did think it was fixedtoo)
Other than that, i can't be of much help. I have mucho to learn about trannys
