tapping into courtesy lights?
Old Jul 23, 2007 | 09:03 PM
trauts83's Avatar
trauts83
Default tapping into courtesy lights?
2006 SLT-
does anyone know where i can tap into the courtsey light circuit....the circuit that has power when you use the key FOB to unlock the doors (turning on the courtesy light and cargo lights)? i'm trying to throw a relay in the loop so i can power some extra courtesy lights for my step bars.
maybe the door ajar circuit would work? but where should i tap it?
any help is appreciated
Old Jul 23, 2007 | 09:09 PM
NickBeek's Avatar
NickBeek
Default RE: tapping into courtesy lights?
The guy that did my running boards tapped in to the wiring harness under the truck along the frame rail. I don't know off hand the wire color, but if no one else can tell you I will look tomorrow in the light and let you know.
Old Jul 23, 2007 | 09:36 PM
trauts83's Avatar
trauts83
that would be awesome.
do yours only light up with the courtesy lights or do they light up with the running lights as well?
im just looking for the temporary courtesy light action.
Old Jul 23, 2007 | 09:39 PM
NickBeek's Avatar
NickBeek
I actually have both on my running boards. Step lights that workwith the interior lights and some clearance lights that light up with the running lights.
Old Jul 23, 2007 | 09:42 PM
trauts83's Avatar
trauts83
good deal
Old Jul 23, 2007 | 09:52 PM
jakebrake's Avatar
jakebrake
there is a wiring diagram link up in the diy. Its the last link drew posted. It'll give you a wiring diagram for the courtesy lights.
Old Jul 24, 2007 | 06:11 PM
NickBeek's Avatar
NickBeek
Sorry dude, I looked under the truck and they tapped into the lights soemwhere in the cab under the finish stuff. Idon't want to tear out my interior to find it. Check out Jake's link for a schematic, and I would also look for a place that sells running boards on line and see if you can download instructions. Good luck.
Old Jul 24, 2007 | 06:14 PM
speakle's Avatar
speakle
I remember when I put in my remote starter that somewhere it said not to hook into the courtesy lights, dont remember why just dont do it.
