Smoke
Old Jul 24, 2007 | 08:01 PM
brutusjr357's Avatar
brutusjr357
Member
Default Smoke
First diesel 2005 2500 47,000 miles just noticed if I rev it up a bit there is a puff of grayish smoke coming out of the exhaust pipe is this normal because I did not notice it when I firt got the truck used with 39,000 miles.....Truck is stock with gutted intake tube and straight pipe.....
Old Jul 24, 2007 | 08:25 PM
squirtbottle09's Avatar
squirtbottle09
Default RE: Smoke
That is perfectly normal. That is the "black cloud of death" everyone talks about. What causes it is the air/fuel mixture. The black smoke is unused diesel, that is burned out the exhaust. If you get a chip, the smoke will really roll.
Old Jul 24, 2007 | 08:44 PM
triton's Avatar
triton
Default RE: Smoke
grey smoke could be a few things...
you might try changing the fuel filter for starters. You might also try running some fuel additives since the new fuel really lacks it lubrication. Also clean the air filter. A puff or two of greyish/white smoke is normal on a cold start but, you shouldn't be seeing any after that.
It's possible you have a bad injector or one going bad. If the smoke gets white, start looking in that direction. Another possiblity is your fuel pump. They're known to go bad within the miles you have. It would help if you had gauges to check see whats going on.
Old Jul 24, 2007 | 09:50 PM
jakebrake's Avatar
jakebrake
Default RE: Smoke
Sounds like dirty injectors. Go pull a real long hill, get them egts up there.
Old Jul 24, 2007 | 11:51 PM
ga_noplugs's Avatar
ga_noplugs
Default RE: Smoke
ORIGINAL: triton
Mine did that on startup recently/. A little whit smoke and really rough idle for about 15 seconds. Added a quart of PS and ran the H#ll out of it the next day... No more rough idle and it runs like a top now.
Old Jul 25, 2007 | 12:08 AM
squirtbottle09
Default RE: Smoke
I thought he was talking about the normal smoke, lol. Try the lucas in it. I run it everyonce in a while and it seemed to clear up everything and makes it run smoother.
Old Jul 25, 2007 | 12:24 AM
jakebrake's Avatar
jakebrake
Default RE: Smoke
It shouldn't blow any smoke sitting in neutral and reving the engine. When you take off from a stop there will be a little smoke, that is normal.
Old Jul 25, 2007 | 09:39 PM
brutusjr357
Member
Default RE: Smoke
This is in park hit the gas and let off and a puff of smoke everytime I do it just started as far as I can tell?
Old Jul 25, 2007 | 09:41 PM
jakebrake's Avatar
jakebrake
Default RE: Smoke
Dump in some fuel additive and go get them egts high. Should solve the problem
Old Jul 25, 2007 | 10:06 PM
Drew's Avatar
Drew
Default RE: Smoke
ORIGINAL: jakebrake
It shouldn't blow any smoke sitting in neutral and reving the engine. . . . . .
mine does
