Loud SQUEAL from belts and pulleys area?
Old Jul 27, 2007 | 08:40 PM
sallyman1's Avatar
sallyman1
Default Loud SQUEAL from belts and pulleys area?
I have a 2004 dodge ram 2500 4X4 Cummins diesel 5.9litre. Today a squeal sound started coming from belt area. to eliminate other things I pulled belt completely off and squeal was gone. I also noticed my belt being eaten or chewed away on the 1 side quite a bit as it was riding over more on the pulley than it should. I spun all accesories. AC was quiet, water pump quiet, ps pump quiet, idler quiet. Only 1 that made noise was the belt tensioner. It sounds rough. fan makes a lil noise but not much. Could it be just the tensioner? has any1 else encountered this and what was it?
Old Jul 27, 2007 | 08:49 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: Loud SQUEAL from belts and pulleys area?
replace the tensioner...mine went out and ate the whole belt!!!
otherwise, the squeel is pretty normal with a diesel on shut down.
Old Jul 27, 2007 | 09:30 PM
jakebrake's Avatar
jakebrake
Bad tensioner, replace it. Check to see if how much play is in the fan hub (try moving it side to side)
Old Jul 27, 2007 | 10:09 PM
sallyman1's Avatar
sallyman1
no play in anything. fan is good no play. only play and bearing noise in the tensioner. How much is a tensioner and belt roughly? I wonder if it would be covered under the LUBRICO warranty I have.
Old Jul 27, 2007 | 10:42 PM
Kev_n_AZ's Avatar
Kev_n_AZ
$65 or so at autozone..plus a new belt at about $25 or more!!!
Old Jul 29, 2007 | 10:37 AM
sallyman1's Avatar
sallyman1
Thanks. I replaced belt and tensioner and sound is gone
Old Jul 29, 2007 | 01:08 PM
Kev_n_AZ's Avatar
Kev_n_AZ
great!!!
happy to hear it!
Old Oct 12, 2012 | 06:11 AM
iwhitne's Avatar
iwhitne
doing mine this weekend... the sounds is horrible
