parkin brake
Old Jul 29, 2007 | 09:57 AM
Drew's Avatar
Drew
Default RE: parkin brake
ORIGINAL: kg1687
I believe parking brake is a drum brake inside your brake caliper on the rear. Doesn't affect your discs at all.
thats it
Old Jul 29, 2007 | 10:25 AM
GFB's Avatar
GFB
So it's safe to say if you're having to tighten down on the cable adjuster a lot, then the parking brake pads are probably worn? Guess it's time to pull the rotors and take a look.[:@]
How do they wear, you say? It's kinda hard to notice when the parking brake is on sometimes with the cummins. [sm=icon_rofl.gif]
Old Jul 29, 2007 | 10:41 AM
sallyman1's Avatar
sallyman1
seriously?theres no drum is there? I have 4 wheel disc brakes...i wonder how the park brake works
Old Jul 29, 2007 | 01:08 PM
finny's Avatar
finny
mayeb it just clamps regular brakes
Old Jul 29, 2007 | 01:09 PM
Kev_n_AZ's Avatar
Kev_n_AZ
work your p brake a few times.. I do not know if they adjust in reverse. bur there may be an easier way to adjust then crankin on the cable
Old Jul 29, 2007 | 04:36 PM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: sallyman1
see my post above
Old Jul 29, 2007 | 08:27 PM
quah 01's Avatar
quah 01
well my truck has disc brakes on the back too and ive already adjusted the cable all the way up i didnt know if it just clamped my regular brake pads together cause they look good or if it clamped something else that may be bad
Old Jul 29, 2007 | 08:32 PM
Drew's Avatar
Drew
your rear disks are a two section disk. you have the outer section for the disk, then you have an inner drum milled into the piece.
you need to jack up the back end and make sure you didnt over adjust the brake. just turn each wheel by hand, you shouldnt hear any metal to metal rubbing.
