parkin brake
Old Jul 28, 2007 | 03:09 PM
quah 01's Avatar
quah 01
Default parkin brake
i was wonderin how the parkin brake worked on the 01 2wd 2500 with disc brakes if ne one could help it would be really beappreciatied thanks again guys
Old Jul 28, 2007 | 03:41 PM
FroneDaddy's Avatar
FroneDaddy
Default RE: parkin brake
Step on the pedal
Old Jul 28, 2007 | 03:46 PM
swilsone's Avatar
swilsone
Funny stuff...but seriously. There are a set of brake shoes inside the hub.
Old Jul 28, 2007 | 03:48 PM
JimmyDiablo's Avatar
JimmyDiablo
ORIGINAL: FroneDaddy
Step on the pedal
Is that how it works?
Old Jul 28, 2007 | 04:32 PM
Captain Squalus's Avatar
Captain Squalus
PARKING BRAKE
DESCRIPTION
The parking brakes are secured to a support plate (1)
and operated by a system of cables and levers
attached to a primary and secondary shoe (2) positioned
within the drum section of the rotor.
The drum-in-hat design utilizes an independent set of
shoes (2) to park the vehicle.
OPERATION
To apply the parking brake the pedal is depressed. This creates tension in the cable which pulls forward on the park
brake lever. The lever pushes the park brake shoes outward and into contact with the drum section of the rotor. The
contact of shoe to rotor parks the vehicle.
A torsion locking mechanism is used to hold the pedal in an applied position. Parking brake release is accomplished
by the hand release.
A parking brake switch is mounted on the parking brake lever and is actuated by movement of the lever. The switch,
which is in circuit with the red warning light in the dash, will illuminate the warning light whenever the parking brake
is applied.
Parking brake adjustment is controlled by a cable tensioner mechanism. The cable tensioner, once adjusted at the
factory, should not need further adjustment under normal circumstances. Adjustment may be required if a new tensioner,
or cables are installed, or disconnected.
[IMG]local://upfiles/56817/8310B2F1433842209FBF570A8BC95A03.jpg[/IMG]
Old Jul 28, 2007 | 06:35 PM
finny's Avatar
finny
^^yah wut he said ^^
Old Jul 28, 2007 | 07:37 PM
JimmyDiablo
So you dont step on the pedal?
Old Jul 28, 2007 | 07:38 PM
lilfroger's Avatar
lilfroger
Jimmy you've got a special parking brake - - mud and 2 little trucks
Old Jul 28, 2007 | 07:43 PM
JimmyDiablo
ORIGINAL: lilfroger
Ouch
Old Jul 29, 2007 | 05:09 AM
kg1687's Avatar
kg1687
I believe parking brake is a drum brake inside your brake caliper on the rear. Doesn't affect your discs at all.
