Pyrometer?
Old Jul 31, 2007 | 03:17 PM
  #31
timesublime's Avatar
timesublime
Default RE: Pyrometer?
I cannot remember, but it is less than that of the 5.9 isb's
Old Jul 31, 2007 | 03:40 PM
  #32
Joel_MD's Avatar
Joel_MD
ORIGINAL: ga_noplugs
ORIGINAL: hildenja
Yes, my turbo apparently has a water jacket around it.
I guess with adding the regen cycles and extra heat they needed to add some active cooling on the turbo. So what is the gallon capacity of the radiators on these new 6.7's?
I believe it's 23 quarts. I'll check my manual when I get home.
Old Jul 31, 2007 | 03:52 PM
  #33
timesublime
5.9----28 quarts
6.7----22.6 quarts
Old Jul 31, 2007 | 04:45 PM
  #34
Drew's Avatar
Drew
REALY. . .I figured the 6.7 would hold more. . .well then, guess you can chalk it up to radiator effeciency
Old Jul 31, 2007 | 04:52 PM
  #35
Sereguial's Avatar
Sereguial
It might be a factor of less coolant capacity in the actual engine block( if the blocks are similar then the cylinder space had to come from somewhere), and plus a turbo doesn't add much more coolant to the system really, maybe another quart or so... obviously depending on the size...
Old Jul 31, 2007 | 04:59 PM
  #36
Drew's Avatar
Drew
the actual block is a bit larger to handle the increased size of the holes. . .I guess the coolant loss may come from where the cylinders are siameased 1-2, 3-4, 5-6.
Old Jul 31, 2007 | 06:45 PM
  #37
timesublime
Or possibly the charge air cooler is bigger and takes some of the radiator space up??
Old Jul 31, 2007 | 06:48 PM
  #38
timesublime
ORIGINAL: Drew
In this application what does Siamesed mean. The old chrysler wedge motors were siamesed on the middle exhaust ports, are the pairs of cylinders joined by webbing for strength?
Old Jul 31, 2007 | 07:58 PM
  #39
Sereguial's Avatar
Sereguial
What I believe Drew means is something that is done on quite a few inline engines for space saving and rigidity of the cylinders(I know it was done on Datsun 280ZX...). What they do is put the cylinders a little closer together (or not, depending on application), and not have a coolant passage between them (or at least not the full length of the cylinder), so the 1-2 siamese looks like an "8" where non-siamesed are "o o" with space. If that makes sense...
I have heard that siamesed engines typically have problems with cooling... I hope that doesn't become a problem on the 6.7L when adding power...
Old Aug 1, 2007 | 01:01 AM
  #40
timesublime
the 8 cooling is reasonable. Maximizes cooling without lacking structure. this is the "webbing" i was talking about. More potential is my guess given heat exchange would be comparable.
