Valve Adjustment
Old Jul 30, 2007 | 07:22 PM
CowboyBob's Avatar
CowboyBob
Default Valve Adjustment
Wasn't someone going to do a DYI for valve adjustment?
Old Jul 30, 2007 | 07:24 PM
quah 01's Avatar
quah 01
Default RE: Valve Adjustment
that would be nice to know how to do
Old Jul 30, 2007 | 07:39 PM
Drew's Avatar
Drew
I do remember someone saying something. . .I have the procedure on paper, but nothing to go with it.
Old Jul 30, 2007 | 08:01 PM
jakebrake's Avatar
jakebrake
Yeah, haven't gotten to it yet. Too much stuff to do on the weekends still. I'll keep trying to get to it.
Old Jul 30, 2007 | 08:05 PM
steve05ram360's Avatar
steve05ram360
I had planned on doing one but havent had the time yet... mine would be on the '05
Old Jul 30, 2007 | 08:32 PM
CowboyBob's Avatar
CowboyBob
How do you tell if the engine is in TDC???
Old Jul 30, 2007 | 08:36 PM
steve05ram360
look at the valves, both intake & exhaust should be closed IMO... same as a gasser...
Old Jul 30, 2007 | 08:40 PM
jakebrake's Avatar
jakebrake
Pull off the tube that is on the carnkcase breather. Then that breather elemant twists off. In there you can see the tdc mark. Simply rotat the engine over till it lines up, then go underneath and mark the tooth on the flywheel. Adjust valves 1,2,3,6,7,10. Then rotate the engine over till the flywheel tooth is in the same spot. Adjust valves 4,5,8,9,11,12.
Old Jul 30, 2007 | 08:46 PM
Drew's Avatar
Drew
one way is to watch #5 intake valve. when it goes down your getting close. . .at the moment it starts going back up your at TDC #1
or you can watch #6. when the exhaust is going up and the intake going down your there.
Old Jul 30, 2007 | 09:13 PM
Parts/Service's Avatar
Parts/Service
STANDARD PROCEDURE—VALVE LASH ADJUSTMENT AND VERIFICATION
NOTE: To obtain accurate readings, valve lash measurements AND adjustments should only be performed when the engine coolant temperature is less than 60° C (140° F).
The 24–valve overhead system is a “low-maintenance” design. Routine adjustments are no longer necessary, however, measurement should still take place when trouble-shooting performance problems, or upon completion of a repair that includes removal and installation of the valve train components.
[ol][*]Disconnect battery negative cables.[*]Remove cylinder head cover (Cylinder Head Cover and Gasket) (Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - REMOVAL).[*]Remove the fuel pump gear access cover (CRANKCASE BREATHER ASSEMBLY-LATE BUILD).[*]Using the crankshaft barring tool #7471–B, rotate the engine and align the pump gear mark with the top dead center (TDC) mark on the gear housing cover (Fuel Pump Gear Timing Mark Orientation). [*]With the engine in this position (pump gear mark at 12 o'clock), valve lash can be measured at the following rocker arms: INTAKE 1–2–4 / EXHAUST 1–3–5[/b]. Measure the valve lash by inserting a feeler gauge between the rocker arm socket and crosshead (Measuring Valve Lash). Refer to VALVE LASH LIMIT CHART for the correct specifications. If the measurement falls within[/b] the limits, adjustment/resetting is not [/b]necessary. If measurement finds the lash outside[/b] of the limits, adjustment/resetting is [/b]required.
INTAKE[/b]
EXHAUST[/b]
0.152 mm ( 0.006 in.) MIN.
0.381 mm (0.015 in.) MIN.
0.381 mm (0.015 in.) MAX.
0.762 mm (0.030 in.) MAX.
note: If measured valve lash falls within these specifications, no adjustment/reset is necessary. Engine operation within these ranges has no adverse affect on performance, emissions, fuel economy or level of engine noise.[*]If adjustment/resetting is required, loosen the lock nut on rocker arms and turn the adjusting screw until the desired lash is obtained:
[ul][*]INTAKE[/b] 0.254 mm (0.010 in.)[*]EXHAUST[/b] 0.508 mm (0.020 in.) [/ul]Tighten the lock nut and re-check the valve lash.[*]Using the crankshaft barring tool, rotate the crankshaft [/b]one revolution (360°) to align the pump gear mark to the 6 o'clock position in relation to the TDC mark on the gear housing cover (Fuel Pump Gear Timing Mark Orientation).[*]With the engine in this position (pump gear mark at 6 o'clock), valve lash can be measured at the remaining rocker arms: INTAKE 3–5–6 / EXHAUST 2–4–6[/b]. Use the same method as above for determining whether adjustment is necessary, and adjust those that are found to be outside of the limits.[*]Install the cylinder head cover (Cylinder Head Cover and Gasket) (Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - INSTALLATION).[*]Install the fuel pump gear access cover.[*]Connect the battery negative cables. [/ol]
hope this helps. The blue lines refer to pictures. If you need the pics let me know and i will send them to ya.
