power steering
Old Jul 31, 2007 | 12:49 PM
shampoo's Avatar
shampoo
Default power steering
i think the power steering pump shot it. the fliud is fine. my truck has 110000 on it. i knew of another o3 that had the same deal around 10000. anybody had this trouble at this miles?
Old Jul 31, 2007 | 01:03 PM
CowboyBob's Avatar
CowboyBob
Default RE: power steering
Dude, I am on my fourth steering gear box at 172k. If you got 110k on yours, you are lucky. Just don't go and get one from the dealer. It cost 3 times as much and is a piece of crap. Get a good aftermarket one from some place like PSC or you'll be replacing it again sooner rather than later.
It also wouldn't hurt to put a stabilizer on it, not only will it drive better, it will make the steering gear box last longer. I think PSC has a lifetime warranty on the gear box if you use one of their stabilizers.
Old Jul 31, 2007 | 01:08 PM
shampoo's Avatar
shampoo
thanks. that so much horsesh-t. it should last alot more than that.
Old Jul 31, 2007 | 01:17 PM
finny's Avatar
finny
i think my power steering pump is dieing because i getting a vibration when i turn hard. any one know how much one of these cost. i think i will change the steering box too.
Old Jul 31, 2007 | 01:22 PM
steve05ram360's Avatar
steve05ram360
do you guys ever swap the fluid?
https://dodgeforum.com/m_856966/tm.htm
mine took 10~15 minutes max to do.
Old Jul 31, 2007 | 01:26 PM
shampoo's Avatar
shampoo
never have. maybe i should.
Old Jul 31, 2007 | 02:02 PM
kg1687's Avatar
kg1687
I have a 124k On my truck my steering box is ok so far. Whines a little, but not bad. I need to swap the fluid but haven't gotten to it yet. Probably run in and have dodge or jiffy lube do it because i don't wanna. I was going to but.... Decided not to because I didn't have the help to do it. according to haynes manual you have to pop off the return line and turn the wheel back and forth slowly and dump more fluid in at the same time.
Old Jul 31, 2007 | 02:06 PM
steve05ram360
KG, I was able to drop the lines into a bucket and turn the wheel myself... still only took 10~15 minutes to do. I did notice my PS pump did not whine as much when I was done. It is so easy to do I plan on doing it on 30k intervals... for $5 bux of fluid, it's worth it to me.
Old Jul 31, 2007 | 03:03 PM
shampoo's Avatar
shampoo
anybody checked $ on this things?
Old Jul 31, 2007 | 04:56 PM
Sereguial's Avatar
Sereguial
That kind of worries me... I am planning on changing my fluid this coming few weeks, but doesn't the steering pump give hydraulic pressure to the brakes for boosting? Does that mean that brakes are like manual brakes if you loose a power steering pump/fluid? That sounds like a bad combo; loss of power steering and power brakes at the same time...
