Now that can't be good!
Old Aug 2, 2007 | 02:43 PM
kg1687's Avatar
kg1687
Default RE: Now that can't be good!
What am I looking for here drew? iF it's wet with fuel good? if it's not wet with fuel Bad or vice versa? Also it only does it when it warms up so should I warm it up and then pull it off?
Old Aug 2, 2007 | 07:50 PM
finny's Avatar
finny
i dont think you need diff temp guages. unless you race or do sled pullin i dont think you need to worry about those
Old Aug 2, 2007 | 08:27 PM
Drew's Avatar
Drew
dont pull the whole valve off, just the banjo bolt at the top. . .you can do this cold. if you have fuel come from the tube or seep out while running then it is bad.
Old Aug 3, 2007 | 12:53 AM
Kev_n_AZ's Avatar
Kev_n_AZ
have ya loosened up the fuel supply lines to the injectors while idling in gear?
set the P brake. start the engine. place it in drive or have a helper drop it in 1st. turn on the a/c full.
now slowly break the fuel lines loose at the injectors. there should be a fine hard spray of fuel. tighten it. go through them all. the one or ones that are weaker will be the probs. it may take a few times to figure it out. also look for idle change. if the loss of fuel does not change idle, that is a hum dinger of a clue.
good luck....
Old Aug 3, 2007 | 04:03 AM
kg1687's Avatar
kg1687
Thanks. Well Drew if i'm not mistaken you want the engine to be running after the banjo bolt is removed or loosened?
Old Aug 3, 2007 | 04:05 AM
kg1687's Avatar
kg1687
Also baja fun, what would be wrong if I did find weaker injector lines? And I can't idle in gear also. My trucks a stick, if it was idling in gear it'd either be not running or going down the road or into something.... I don't really want to sit over the engine with it moving either.... would be interesting though. For someone else.
Old Aug 5, 2007 | 12:42 AM
kg1687's Avatar
kg1687
K Drew Umm.. You didn't reply to my message on if it should be running or not. So i'm going to start it and see if anything happens. Watch i get diesel injected into my arm WOO HOOO!
Old Aug 5, 2007 | 12:52 AM
jakebrake's Avatar
jakebrake
You check it at idle.
Old Aug 5, 2007 | 01:27 AM
kg1687's Avatar
kg1687
ok thanks jake
