Autometer Gauges
Old Aug 1, 2007 | 01:57 PM
kg1687's Avatar
kg1687
Default Autometer Gauges
Hey are the Autometer Phantom Gauges pretty decent? What about Issopro. In my gauges selection I have one ISSOpro?
Thanks
Old Aug 1, 2007 | 05:50 PM
Mayfair's Avatar
Mayfair
Default RE: Autometer Gauges
I almost wentt with the isspro's, but I liked the electronic fuel pressure gauge and Autometer offered it so I went with Autometers. Now that I have them, I'm happy I did.
Old Aug 1, 2007 | 08:45 PM
Dharris's Avatar
Dharris
ORIGINAL: kg1687
Thanks
I use the Phamtom series and I'm please with them. The green covers for the lamps do not match the original equipment colors well but they are ok. I don't like their temp probs.They are the old style that use two nuts and a lock washer rather then a formed electical connector like other gauges manufactures do.
I have never used ISSpro.
Old Aug 1, 2007 | 10:02 PM
sharx ram's Avatar
sharx ram
I run the Phantom guages also but have blue LED interior, the green LED would match the factory color
Old Aug 2, 2007 | 04:00 AM
kg1687's Avatar
kg1687
K. I'm running a dual pyro set up. One on the exhuast manifold (issopro because it has the color analog gauge setup green-yellow-red) and then the Autometer Phantom. Everything else should be Autometer Phantom. I figured up where all of my extensive number of gauges Are going. Everybody here is probably going to think I'm an idiot for my choices but ehh... at least I'll be pretty sure if something is going wrong.
Old Aug 2, 2007 | 08:45 AM
speakle's Avatar
speakle
I was looking at the autometers last night at DM and they look much better isspro. I could be wrong but isspro's look somewhat cheap when put next to one of the nice autometers.
Old Aug 2, 2007 | 11:41 AM
RamFreak's Avatar
RamFreak
I am getting ready to do gauges, I am going with the Autometers as well. Is there any way of installing the pyro and boost without voiding warranty?
I want to install the pyro after the turbo, that is the best to judge safe EGT's for shutdown correct?
Old Aug 2, 2007 | 01:10 PM
Mayfair's Avatar
Mayfair
YEP !!!
After the turbois where you'd want it for turbo cool down.
Old Aug 2, 2007 | 01:18 PM
Dharris's Avatar
Dharris
ORIGINAL: 07CTDPOWER
If you have a Jake Brake there is a port for the probe.
Old Aug 2, 2007 | 02:51 PM
kg1687's Avatar
kg1687
That's the issopro gauge i was planning on running.
Also I was planning on running some of my gauges in the cubby hole spot that the 3rd gen have .
Then planning on running the rest either here
and possibly here
Also going to have a 2 gauge steering column pod set up. But might change for the above becuase it looks pretty cool.
