What is this called!
Old Aug 7, 2007 | 04:21 AM
kg1687's Avatar
kg1687
Default What is this called!
K. I believe according to drew this thing is broke. But I'm not sure what the technical name is for it. I asked. They were like what are you talking about. Tried to give me some bull **** about how i was wrong. Pissed me off I told them I wasn't and I knew what was wrong and that this is what I needed. They got upset. Never the less besides the point what is it?
[IMG]local://upfiles/67149/8561128CE7A44B4DBBCAC4802B4499CE.jpg[/IMG]
Old Aug 7, 2007 | 08:07 AM
triton's Avatar
triton
Default RE: What is this called!
that's the relief valve on your rail. It prevents you from running too much psi at the rail. I believe it's designed to blow out at 28K psi but, the rail itself an take up to 30K psi.
I guess it would be hard to tell if it's bad. They're designed to blow off one time and be replaced. I an't imagine how you would have blown it though.
That's a mighty purrtie engine.
Old Aug 7, 2007 | 10:57 AM
Drew's Avatar
Drew
yup. . .rail relief valve. . .I snagged that pic from TDR which was a demo cut-a-way engine of the 6.7L.
I'd like to have a set of them fancy chromed out injector lines
Old Aug 7, 2007 | 11:17 AM
triton's Avatar
triton
ORIGINAL: Drew
Ahhh, that's why the looked so pretty. Yeah, you aren't kidding... I like some of the lines too !
Old Aug 8, 2007 | 04:10 AM
kg1687's Avatar
kg1687
K drew you said if i cracked that banjo bolt that no fuel should be coming out of it at idle right? Well I cracked it a 1/4 of a turn is that too much? Anyways Fuel just started pouring out of it. OH btw drew did your wife have the kid? Sorry I work swing shift might have missed the post. Hope all is well. Back to my question that means it's bad according to the previous post correct?
Old Aug 8, 2007 | 07:59 AM
CamperAndy's Avatar
CamperAndy
The outlet of the relief feeds back to the tank and is the same return line as for the injection pump bypass return and will be full of fuel all the time.
Old Aug 8, 2007 | 08:10 AM
Drew's Avatar
Drew
the 03's I believe have a seperate line running back to the tank from the rail relief valve. . .and realy the best thing to do would be to remove the line all the way. if you have fuel comeing out of the valve then it is bad.
Old Aug 8, 2007 | 08:14 AM
triton's Avatar
triton
Drew, you should be sure to warn about messing with that rail while under pressure !!
Old Aug 8, 2007 | 10:46 AM
Drew's Avatar
Drew
yea. . .I sometimes miss that. . .get cought up in the working part and forget that even at idle the rail is running around 5K psi.
