Really need help
Old Aug 26, 2007 | 11:30 PM
bway4x4's Avatar
bway4x4
Default RE: Really need help
Hrm.. Dont think it is i'll definitely double check that, but even so wouldthe a/c clutchbe loud enough to hear over straight piped exhaust? And actually sound like something to worry about?
Kev_n_AZ's Avatar
Kev_n_AZ
take some stress off, take it to the dealer for service. maybe they will do a ride along with you to listen for the noise.
Old Aug 27, 2007 | 01:07 PM
Mayfair's Avatar
Mayfair
I found the culprit ...
Old Aug 27, 2007 | 06:58 PM
jakebrake's Avatar
jakebrake
I can hear my clutch kick on and off over my truck's exhaust and intake
Old Aug 27, 2007 | 11:43 PM
gtxpooch's Avatar
gtxpooch
quite frequent and lasts maybe 10-15 seconds at a time.
Does it do it when your turning or all thie time? Maybe the fans hitting the shroud?
Old Aug 28, 2007 | 12:56 AM
AKCerberus's Avatar
AKCerberus
Does it happen at slower speeds, like when you accelerate from a stop light it starts slowly then builds up until about 20 or 30 mph it quits?
Old Aug 28, 2007 | 08:09 AM
bomber59's Avatar
bomber59
I would get it to the dealer before the 1k runs up! I have heard torque convertors make similar noises. Is it an automatic? Is the noise high pitched or low (is the fan runnig fast with the straw or slow)?.It could be something getting into the ring gear at the starter. Does the power steering have plenty of fluid?
Good luck
Jim
Old Aug 28, 2007 | 08:51 AM
Methos's Avatar
Methos
Hm, straw in a fan, that's a good description. I wonder if we're chasing the same noise. I get a noise similiar to what you are describing when I'm slowing down. Never at high speeds, only when I get down to 20-25 with light pressure on the brakes until I come to a stop or take my foot off the brakes. Heavy braking it won't do it. Haven't quite run it down yet. Every time I think I have it figured out I run into another dead end.
I hate chasing noises down, they can be absolutely painful to locate.
Old Aug 28, 2007 | 04:57 PM
bway4x4's Avatar
bway4x4
ORIGINAL: AKCerberus
Yes it starts off at slow speeds usually, then dissappears until about 20-30, then sometimes it'll do it around 50mph as well.
Old Aug 28, 2007 | 05:00 PM
bway4x4's Avatar
bway4x4
It's a 6 speed manual, Yes it sounds like the ("Straw in Fan") Fan is moving fast. Does it all the time whether i'm turning or not.
Also Menthos, Mine seems similiar, however mine does it whether i'm braking or not.
