Need new engine
Old Aug 27, 2007 | 09:32 PM
99dually's Avatar
99dually
Default Need new engine
Sorry if the is in the wrong section.
My truck is in need of a new engine. It had a crack in the block, and the coolant ran out, so it overheated to the point that it is no longer repairable. I'll be replacing the full engine, not just the block.
It is a:
1999 Dodge Ram 3500 Turbo Diesel
I mainly need to know from what other year's the engines will fit. Like will a 98, 00, 01 so on and so forth "bolt right up" so to speak? I'll be calling junkyards fairly soon, and would just like to know my options. Thanks
Old Aug 27, 2007 | 09:41 PM
Silverline's Avatar
Silverline
Default RE: Need new engine
As long as its a '98 through (I think '03) everything should bolt up fine. You would have to make sure that the '98 would be a 24 valve and not a 12 valve since they offered both that year. And your computer would already be set up to run with the VP44 which was in until '03 (I think). Drew would know better about that.
Old Aug 27, 2007 | 10:16 PM
jakebrake's Avatar
jakebrake
02 is the last year of the vp44 so you need a 98-02. However there are differences between the engines, nothing inside though. You'll be able to swap you parts onto the engine. I beleive the turbos are different depending on year and trans and that's about it.
Old Aug 27, 2007 | 11:49 PM
gtxpooch's Avatar
gtxpooch
Right section far as I know, BTW, Welcome!!
Old Aug 28, 2007 | 05:00 AM
99dually's Avatar
99dually
Ok, awesome, thanks for the responses guys. I'll call around the junkyards and whatnot today. Anybody know of any decent places online? I'm in Minnesota, so anywhere that's near here, or that ships freight nice and cheap would be great.
Old Aug 28, 2007 | 07:09 AM
Drew's Avatar
Drew
sounds like you got bitten by a '53' block.
they may be hard to come by, but you might be able to find some VP44 ISB's out of the larger fed-ex and UPS vans. the smaller ones usualy come with 4bt's.
