New brand name oil
Old Aug 28, 2007 | 08:27 PM
simonsj's Avatar
simonsj
Default New brand name oil
Bought a 2001 cummings, i was told that when i take for a oil change i should use the same brand of oil. Is that true?
Old Aug 28, 2007 | 09:18 PM
Parts/Service's Avatar
Parts/Service
Default RE: New brand name oil
Use a good name brand like MOPAR, Rotella or Dello.
From the shop manual........
In diesel engines, use an engine oil that conforms to API Service Grade CF-4 or CG-4/SH (API Service Grade Certification Label—Diesel Engine Oil). MOPAR® provides an engine oil that conforms to this particular grade.
SAE VISCOSITY
An SAE viscosity grade is used to specify the viscosity of engine oil. SAE 15W–40 specifies a multiple viscosity engine oil.
When choosing an engine oil, consider the range of temperatures the vehicle will be operated in before the next oil change. Select an engine oil that is best suited to your area's particular ambient temperature range and variation. For diesel engines, refer to (Engine Oil Viscosity Recommendation—Diesel Engines).
Old Aug 28, 2007 | 09:24 PM
FroneDaddy's Avatar
FroneDaddy
Welcome, who makes the cummings?
Old Aug 28, 2007 | 09:29 PM
gtxpooch's Avatar
gtxpooch
Cummins makes Cummins, there's no "g" in Cummins
Old Aug 28, 2007 | 09:37 PM
JimmyDiablo's Avatar
JimmyDiablo
Welcome, Brand does not matter as long as it is reputable.
Old Aug 28, 2007 | 09:40 PM
Silverline's Avatar
Silverline
Just use a good brand name that meets the trucks specs. Wally World's SuperTech probably isn't a good idea...I know some people that use it religiously, and have burned up motors with it.
Old Aug 28, 2007 | 10:44 PM
CutterW's Avatar
CutterW
Rotella 15W40 is what I use.
Old Aug 28, 2007 | 11:01 PM
02cummins's Avatar
02cummins
i will be using royal purple synthetic long rider 15w-40
Old Aug 29, 2007 | 07:44 AM
Drew's Avatar
Drew
I used delo 400 for a while and didnt have any problems. . .running amsoil right now and things are going pretty good.
Old Aug 29, 2007 | 12:01 PM
DBLR's Avatar
DBLR
My vote goes to Dello 400 but if you cant get Dello then look for either Mobil Delvac or Valvolin Cummins Blue.
