Question on changing fuel filter
Old 08-30-2007 | 10:18 AM
cujo's Avatar
cujo
Default Question on changing fuel filter
Hey guys, I read the DIY about changing the fuel filter and have one question. After changing the filter it states to turn the switch to run, wait for the pump to stop. Then bump the starter and wait for the pump again. My question is: bump the starter from the run position the switch is in already OR turn the switch off, then back on (cycling it) to bump the starter, or does it matter? Rather not botch it up and have to start bleeding the lines my first time through. Thanks in advance.
OK I lied, second question. Use the 7 micron filter??
Old 08-30-2007 | 10:28 AM
UpBranchLiner's Avatar
UpBranchLiner
Default RE: Question on changing fuel filter
Bump it from the run position its already in. Make sure you listen for the lift pump, it can be hard to hear with alot of background noise.
Old 08-30-2007 | 10:53 AM
Drew's Avatar
Drew
you can use the 7 micron filter. . .thats fine.
Jake's got it right, just act like your starting the motor, but only bump it
Old 08-30-2007 | 10:58 AM
cujo's Avatar
cujo
Got it. Thanks.
Old 08-30-2007 | 12:02 PM
Master Baiter's Avatar
Master Baiter
While we're on the subject of changing fuel filters, I changed mine Tuesday and ever since then, cold starts produce a lot of white smoke and idles rough. Once it warms up it seems to be OK. Have I done something wrong? I also changed the air filter, oil, and oil filter. Truck is a 06 with 11,500 miles.
Old 08-30-2007 | 01:15 PM
farmerguy's Avatar
farmerguy
i cant find link on changing fuelfilter. can anyone provide for me? thx,,,
Old 08-30-2007 | 01:35 PM
cujo's Avatar
cujo
https://dodgeforum.com/m_485543/tm.htm
Old 08-30-2007 | 02:28 PM
Drew's Avatar
Drew
ORIGINAL: Master Baiter
find a steep hill and run your truck hard a few times, get your EGT's and boost numbers up. . .sounds like you may have had a piece of trash get into your system somewhere.
if that doesnt do it your FCA is probably sticking closed when cold.
Old 08-30-2007 | 10:53 PM
gtxpooch's Avatar
gtxpooch
Speaking of trash in the system, I changed my filter today and noticed some"trash" or something inthe filter housing, couldn't really tell what it was. What's the best way to get that crap out without making a mess??The housing was about 1/2 full of fuel.
Old 08-30-2007 | 11:23 PM
cujo's Avatar
cujo
I haven't done mine yet, but doesn't the housing drain completely when you open the valve and leave it open?
Quick Reply: Question on changing fuel filter
