Oil Change Required...
Old Sep 17, 2007 | 10:46 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: Oil Change Required...
Parts/Service
not to argue about the oil change light.
at a local dodge dealer, i have a an associate that is asst mgr of sevice. been with dodge 20 yrs now. a friend of mine bought a new 07 6.7 cummins at the start of summer. his oil change light came on. took it in, they reset it. they mentioned nothin about it being cyclicable.
then his check engine light came on. they flashed it, came back on the next mornng. they flashed it again. now he has a company document that says he may drive with the engine light on till they can fix the firmware.
hes had the oil changed regularly as prescribed by dodge in the hand book at 7500 or less miles.
no problems except firmware updates that dont work.
Old Sep 17, 2007 | 11:00 PM
Parts/Service's Avatar
Parts/Service
I just looked and didn't see any flashes that applied to oil changes or oil change indicator. The trucks computer takes varibles into consideration to determine when the oil needs changing. It looks at how the truck is used. idle time, speeds, stop and go driving. Each truck is going to be different according to how you drive.
Which flash did they say wouldn't work. We do flashes everyday and usuallyhave no trouble at all. See if you can find out and I will check into it.....
Old Sep 19, 2007 | 12:15 AM
6.7cummins's Avatar
6.7cummins
My change oil came on at 2250 called the dealer they told me 1 they did not even know the diesel truck had that feature 2. go ahead and rest it no problem went to dealer the other day flashed my computer said i did not have the update?
Old Jan 10, 2008 | 12:58 PM
bs5spinna's Avatar
bs5spinna
2800 miles on mine and have the same issue. I didnt take it in, but called service and they said - "just fiddle with it and try to reset it." I think I'll be taking it to another service department.
Old Jan 10, 2008 | 02:44 PM
Mayfair's Avatar
Mayfair
Parts/Service - are you starting to see a pattern here?
You are the ONLY dealer in America who is not only honest, but also gives a flying ***** and knows whatthe hell they aredoing. [:@]
God Bless ya brotha !!
Old Jan 10, 2008 | 02:56 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: handymanherb
Get a quick drain and do it yourself it less than 10 minutes and not make a mess at all.
Another member just got an sample back from the lab and it said he was good to go 1500 more miles and his light was on
fwiw... mine takes 20~30 minutes to drain. using the finger touch valve.
Old Jan 10, 2008 | 03:14 PM
Mayfair's Avatar
Mayfair
ORIGINAL: steve05ram360
You think it takes THAT long?
I'll admit that it's slower, but mine drains a little quicker than that. 5-10 minutes for me, although I warm the enginge up before changing the oil. Maybe that's why.
