h2 wheels
Old Sep 19, 2007 | 07:24 AM
  #21
GOD RAM IT's Avatar
GOD RAM IT
Default RE: h2 wheels
ORIGINAL: Silverline
A word of advice from someone who used a grinder on a set of wheels to get them to fit. Take them to a machine shop and have them take down the centers with a lathe or something a whole lot more accurate than a grinder. My deal was in an emergency since I had badly bent a rim, but the grinder didn't make a perfect circle of the center and the balance on the wheel was messed up and ended up with a bad shake under speed.
think about what you just said. If you grind enough were the lug nuts are able to cnter the wheel than there will never be an issue. Isounds like you didnt grind enough and the rim was binding not allowing the rim to center via the lugnuts.
Old Sep 19, 2007 | 07:55 AM
  #22
Drew's Avatar
Drew
if you take the wheels to a machine shop, thell them the finished whole dia. should be 4.774" +/-.003
Old Sep 19, 2007 | 08:12 AM
  #23
Silverline's Avatar
Silverline
No. More like it was an uneven grind and when they went to put the wheels on the balance stand they wouldn't clamp up evenly due to the centers being irregular.
Old Sep 19, 2007 | 08:23 AM
  #24
JDH's Avatar
JDH
Do you suppose acylinder hone on a drill would produce acceptable results. with carefull measurements it may be possible to have them all at a consistant diameter.
I have not heard back from the party that was selling so the deal may be dead but there does seem to be a few out on the market and for the right price may be a good way to get wider rims and cheep rubber.
Old Sep 19, 2007 | 08:30 AM
  #25
Drew's Avatar
Drew
you could, however you will take material off unevenly and that will lead to problems when you try and have them ballanced.
a machine shop will put them on a lathe, center eveything up and remove material at the same rate. I doubt they will charge too much.
Old Sep 19, 2007 | 08:40 AM
  #26
GOD RAM IT's Avatar
GOD RAM IT
oh I thought you were saying that they werent balanced because they mounted un even. my bad.
but if some one wanted to do it with a grinder they could use the dyna beads or equal and it would eliminate the need to go on a balance machine
Old Sep 19, 2007 | 08:41 AM
  #27
Tommygunz's Avatar
Tommygunz
I may look into these eventually as well. For now the project is towing ability though.
Old Sep 19, 2007 | 09:30 AM
  #28
NCcummins's Avatar
NCcummins
I think them black H2 wheels with the silver center caps look pretty sweet, but I would prob paint my center caps black....if you get some put on, lets see the pics!
Old Sep 19, 2007 | 09:45 AM
  #29
Tommygunz's Avatar
Tommygunz
I think if I were to do them I would actually pain the rims black except the solid ring around the outer rim, then paint the cente caps black except the rams head. Future plans though, nothing in the near future.
Old Sep 19, 2007 | 09:56 AM
  #30
GOD RAM IT's Avatar
GOD RAM IT
I tried that and because of how the rims are formed it was hard. I didnt like it either. maybe it would look ok with the chrome H2s but not the alloy colored ones.
