frickin oil leak!!!
I have a new oil leak on my cummins.
itll be $2000+ to replace the part alone. not including labor!!!
or $ 80 for a new rebuild/ gasket kit.....
the part???
vacuum pump where the shaft for the ps pump goes between....was told its not serious should be fine for a while. but should rebuild pump soon. [:@]
the part???
Go to www.fixinrams.com, great kit, everything you need, the whole job done in about 3 hours. Kit includes 2 sets of seals, necessary tools, gasket, written instructions and a video that shows you how to do the job. Or send you pump to him and he will do it. I did mine and it worked great.
I also bought his kit and it works great. Don't buy a new or rebuilt pump to fix the problem, because it will more than likely have the same crappy seal in it and you'll have the problem again in no time.
