OBD II scan tools...
Old Sep 26, 2007 | 05:56 PM
  #21
sspp's Avatar
sspp
Default RE: OBD II scan tools...
I have one of the first generation of these. It reads everything I need for diagnostics.
www.scanguage.com
Old Sep 26, 2007 | 07:56 PM
  #22
steve05ram360's Avatar
steve05ram360
this tool looks pretty good... pricey but good. the base unit is $500 IIRC...
http://tunertools.com/proddetail.asp...240-IN-ProPack
Old Sep 26, 2007 | 07:58 PM
  #23
NCcummins's Avatar
NCcummins
man..do i want one now!
Old Sep 26, 2007 | 07:59 PM
  #24
steve05ram360
http://www.aeswave.com/products/Prod...778&tsw=su
$400 bux
Old Sep 26, 2007 | 08:30 PM
  #25
steve05ram360
Ok so I'm looking over the Injectronics CJ4 scanner/tool and the more I look at it, the more I like it. It has an option for activating single fuel injectors for testing purposes and cleaning purposes. the built in scope allows you to capture & analyize data and download it to the pc for archiving purposes. It's expensive if you get the pro pack, $720 from one of the companies that sells it. Think about it, your able to yank your injectors on your wifes ride and clean them the way they should be cleaned... open & close them with solvent going thru them. Capture o2 data with the scope functions... check the map sensor & tps sensors at the same time (2 channel scope) and save up to 10 screen shots.
damn, I'm really liking this tool...
Old Sep 26, 2007 | 08:48 PM
  #26
Jr. Mechanic's Avatar
Jr. Mechanic
ORIGINAL: steve05ram360
ORIGINAL: MCDiver
There a few that you by a cable and the software is free. You hook it up to your laptop and you can do more than you imagined with the truck, even check specs while you are driving down the road.
I havent been able to find anything like that, it would be nice to check out.
NC... yes they read the codes and they also read all of the sensor data that is on the motor. One of them allows you to graph the data which can be helpful for finding faults that are intermittant.
You can do that with the snap-on scanners...
Old Sep 26, 2007 | 09:21 PM
  #27
steve05ram360
yeah but the snap on scanners cost a bunch...
Old Sep 26, 2007 | 09:42 PM
  #28
Drew's Avatar
Drew
after today. . .I'm trying to think of ways I can talk to the wife and let her know I need a smarty for "diagnostic" purposes
Old Sep 26, 2007 | 10:38 PM
  #29
steve05ram360
do you know if the smarty will kill the torque management?
Old Sep 27, 2007 | 07:27 AM
  #30
HankL's Avatar
HankL
I don't have personal experience with this one:
http://www.obd-2.com/#order
but it is one of those that is a free download
and you have the option of making your own cable
or buying one.
other low cost options:
http://www.bowserelectronics.com/
http://www.davisnet.com/drive/products/carchip.asp
http://www.obd2.com/quikcode/quikcode.htm
http://www.autotap.com/
