HOLY FARK!!! Beasty died on me!!!
Old 09-26-2007, 10:26 PM
cujo's Avatar
cujo
cujo is offline
Default RE: HOLY FARK!!! Beasty died on me!!!
Damn that's one long code list. Betcha had to change your shorts when you got home huh? That has to be one of the worst feelings in the world when your ride starts acting up on the highway. Glad it worked out.
Old 09-26-2007, 10:34 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
humm, did I miss it? I dont see it.
Old 09-26-2007, 10:37 PM
cujo's Avatar
cujo
cujo is offline
https://dodgeforum.com/m_984315/tm.htm
steve05ram360
oops, never mind.. found it.
It's also in the back of the FSM...
Old 09-27-2007, 11:46 PM
Twoforme2's Avatar
Twoforme2
Twoforme2 is offline
ORIGINAL: mww
One question, what is the key trick you mentioned and will it work on a '06?
yeah...what he said
Old 09-27-2007, 11:52 PM
NickBeek's Avatar
NickBeek
NickBeek is offline
The "key trick" will work on an '06. With the engine off, you turn the key to the on position (not start just run) then off and repeat till you get to the third on. Then leave it there and look at your odometer. It will have dashed lines all the way accross and then either display any codes that are present or say DONE.
Old 09-28-2007, 12:43 AM
speakle's Avatar
speakle
speakle is offline
I had my first scare the other day. I got in my truck and cranked it but nothing happened after cranking far longer than usual. I stopped and tried again and she fired up and the CEL came on for the rest of the day but eventually went off.
Old 09-28-2007, 01:05 AM
beachmstr's Avatar
beachmstr
beachmstr is offline
thats some rough luck man. sorry to hear about that. at least you knew how to fix it right there on the side of the road. i probably would have been sol.
Old 09-28-2007, 07:20 AM
Drew's Avatar
Drew
Drew is offline
well. . .I figured if I could get an M1A1 back up and running with a paper clip, 550 cord, and a swift hit with a 20lb sledge, my truck shouldnt much harder
Old 09-28-2007, 08:05 AM
speakle's Avatar
speakle
speakle is offline
ORIGINAL: Drew
HOLY $%*%.....is that you MacGuyver??????????? I am such ahuge fan, I used to always watch your show.
Quick Reply: HOLY FARK!!! Beasty died on me!!!
