Codes
Old Sep 27, 2007 | 10:16 AM
SpLaT's Avatar
SpLaT
Default Codes
I had book marked DTC codes listing and for some reason they were deleted or aliens took em... looking up code P2509 for a buddys 05 3500QC any help appreciated.
Thanks
Old Sep 27, 2007 | 10:21 AM
Drew's Avatar
Drew
Default RE: Codes
here is a thread with most of the codes I could dig up https://dodgeforum.com/m_984315/tm.htm
unfortuantely 2509 is not on there. . .but that will be added as soon as I hit ok.
P2509 ECM/PCM Power Input Signal Intermittent
probably have a bad ground somewhere, or the main power to the computer is loose.
Old Sep 27, 2007 | 10:23 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Codes
P2509 is powerdown data lost error- diesel. If you need the diag sheet, just send a pm or post.
Old Sep 27, 2007 | 10:37 PM
SpLaT's Avatar
SpLaT
Default RE: Codes
Seeme some time ago buddy killed his batteries, had them replaced, also threw P0720 output speed sensor circ error.... could be due to bad batteries. Thanks for info
