Diesel Heater???
Old Jun 21, 2012 | 07:20 AM
kpgoldsmith's Avatar
kpgoldsmith
Default Coil Light and Buzzer @ 70 MPH??
On a long trip last week, when I reached 70-75 MPH a light that looks like a wire coil would light and a buzzer buzz 10 times, then go out, then repeat. No codes in the memory??? Any ideas?
New forum user
Old Jun 21, 2012 | 01:04 PM
3dubs's Avatar
3dubs
Originally Posted by Silverline
I'd stick with the tried and true block heater. I've been to about 25 below and had my truck fire with no problem after being plugged in.
I think about the times it is either hard to plug in or you can't. If you are home you could plug it in. But on the road it may be hard to find a plug at times. If you get back up in the woods there are no plugs so it would either be a generator or that diesel heater.
I don't need it down here. But I could use something to keep the inside of the truck cool. I have been burned from a seat before. If I could set a timer to turn the a/c on ...
Old Jun 21, 2012 | 01:23 PM
Jigabop's Avatar
Jigabop
way to revive a 5 year old thread lol...
sounds like maybe your ignition switch is acting up?
what year of truck are we talkin about anyway?
Old Jun 22, 2012 | 07:22 AM
kpgoldsmith
Default Heater coil code
I am going to replace the intake air temp sensor and the air intake charge sensor first. If this doesn't do it, it sounds like the computer flash update I had recently could be causing the problem.
