Rear end 3.73 or 4.10
Old Jun 21, 2012 | 11:49 PM
MNfarmboy's Avatar
MNfarmboy
Default Rear end 3.73 or 4.10
Hi all, I have a 2006 2500 4x4 5.9 cummins and I want to move from 285/70R17 to true 35/12.5/17R Fierce Attitude tires but would like to find out if I have the 3.73 or 4.10 rear end first. I Pulled a number off of the axel (T)X2DH188511090 and (P)52104. I want to still be able to tow my camper and other equipment. Thanks for the help.
Old Jun 22, 2012 | 12:14 AM
scatpack_69's Avatar
scatpack_69
Do it old school; jack up the rearend, trans in neutral, and put a tape line on the driveshaft and one on the tire. Turn the tire and count how many driveshaft rotations you get for every one tire rotation. Most are 3.73.
Old Jun 22, 2012 | 11:59 AM
Jigabop's Avatar
Jigabop
open up your glove box and look at the sticker inside it. it will say axle ratios on the sticker
Old Jun 22, 2012 | 03:44 PM
MNfarmboy's Avatar
MNfarmboy
I like your solution but no sticker in the box. I did find a sticker in my trk info that says 05145 181AB. Does that mean anything? Or is there somewhere I can look up my vin?
Old Jun 22, 2012 | 06:04 PM
Jigabop's Avatar
Jigabop
that sucks...on 2nd gens its on the sticker in the glove box. tells you exactly what rear ends you have, and what axle ratios. for example mine says D60F D80R 4.10 ratio.
no idea what those numbers mean...
if sticker is not in glove box you will have do do like was suggested..tape lines lol...
sticker should be in glove box on 3rd gen on bottom of glove box inside it...if its not there, someone removed it.
anyway 3rd gen trucks are standard equipment 3.73. 4.10 was a optional, but not standard equip.
if you still have factory window sticker for truck that will tell you...if it doesn't mention 4.10, then its not 4.10.
Old Jun 22, 2012 | 10:19 PM
MNfarmboy's Avatar
MNfarmboy
Thx. I do have the original window sticker and no mention of 4.10. When I have the chance I will go old school. Goes with my old guys rule t-shirts.
Old Jun 23, 2012 | 12:42 AM
scatpack_69
I don't believe the later 3rd gen trucks had the glovebox sticker, my 07 doesn't and never has (original owner since 24 miles); my 03 does but only has the VIN on top, then the trim code (for black interior) and the primary (white) and secondary (silver) paint codes.
From my bodyshop days, I remember on occasion checking the paint codes in the glovebox, but those would have been largely up to 05 models since the 06's were new then
Old Jun 24, 2012 | 01:40 AM
Jigabop's Avatar
Jigabop
then you have 3.73
it would have been listed on the sticker if it had it since it was optional equipment.
