injectors or injector nozzles??? why?
Old Oct 7, 2007 | 01:59 PM
blondeguy08's Avatar
blondeguy08
Default injectors or injector nozzles??? why?
I dont understand this very well? Inector nozzles promise the same gains at about half the cost or less than the entire injector... Can stock injectors handle these nozzels? Because i want either stage 2 or 3 injector nozzles....unless someone has a strong argument about getting the entire injector.... my choice is nozzles+lift pump or just the injectors.... Thanks!
Old Oct 7, 2007 | 02:13 PM
blondeguy08
Default RE: injectors or injector nozzles??? why?
please?
Old Oct 7, 2007 | 02:21 PM
sallyman1's Avatar
sallyman1
? i dont get you. The injector has its nozzle atatched to it already doesnt it? I work on heavier diesel engines and it is this way. The injector is all 1 piece in itself whether its a mechanical injector or electronic one.
Old Oct 7, 2007 | 02:56 PM
blondeguy08
http://cgi.ebay.com/ebaymotors/Edge-...spagenameZWDVW
that versus a entire new injector?
Old Oct 7, 2007 | 03:45 PM
sallyman1's Avatar
sallyman1
where does this nozzle hook up to? isnt a 5.9 cummins electronic injector all 1 piece or am i wrong?
Old Oct 7, 2007 | 04:55 PM
NCcummins's Avatar
NCcummins
u cant just get the nozzles? you have to acaully get the whole injector...there i no place to hook up the injector nozzles, they are just 1 peice..PM jake or drew to make sure....but as far as I know, and with my 75 hp injectors and my old stockers was just all one piece...
Old Oct 7, 2007 | 05:16 PM
NickBeek's Avatar
NickBeek
Not sure about the 2nd gens, but you can replace the nozzle only on the 3rd gens. To your original question... If I knew my injecotrs were all good, I would have no problem putting nozzles only on mine.
Old Oct 7, 2007 | 06:00 PM
NCcummins's Avatar
NCcummins
maybe that i true to ours too.but when i took mine out and put the new ones in, they looked like a whole unit instead of seperate peices....
Old Oct 7, 2007 | 07:44 PM
blondeguy08
well my best friend just put nozzles in his 2001 and made a hell of a difference and i was just wondering should i do that or go with the entire injector?
Old Oct 7, 2007 | 08:09 PM
NCcummins's Avatar
NCcummins
i dunno man...i am putting 75hp on my truck tomarow...
