Hard Start
Old Oct 17, 2007 | 08:13 AM
NCcummins's Avatar
NCcummins
Default Hard Start
Got in the truck at about 7 this AM to head out to school. It was only about 45 out. Tried to start the truck but it wouldnt crank. So tried it again, took a second, and started! My FASS was only reading about 11 or 12 for a minute and then went right back up to 16 or 17. Any idea what this could be?
any help is great!
Old Oct 17, 2007 | 09:53 AM
Mayfairisafunnymfer's Avatar
Mayfairisafunnymfer
Default RE: Hard Start
I had a BMW many moons ago that would do this from time to time. The cure? tap on the starter a few times with a wooden handle of some type. Also if you hit the starter (with the ignition) a few times fast it will usually engage it.
Old Oct 17, 2007 | 11:15 AM
Mayfair's Avatar
Mayfair
You turned the key and nothing happened, or you kept trying to turn the motor over and it wouldn't fire up?
Old Oct 17, 2007 | 11:21 AM
Drew's Avatar
Drew
sounds like you werent getting any fuel to the VP44. . .hopefully you dont have a short somewhere to your fass.
Old Oct 17, 2007 | 11:31 AM
Mayfair's Avatar
Mayfair
I'm a little confused because he said it "wouldn't crank". That leads me to believe that he had nothing when he turned the key.
Old Oct 17, 2007 | 11:45 AM
Drew's Avatar
Drew
I read it as the engine would turn. . .she just wouldnt make any fire.
Old Oct 17, 2007 | 04:28 PM
CowboyBob's Avatar
CowboyBob
It could be both. A low or dead battery would not give the FASS thevolts it needs, then whenthe truckfires up and the alternator is turning, it jumps back to wherethe PSIshould be because it has thevolts it needs. Still 11-12 PSI is more than enough to start the truck. My in-tank pump never showed a 2 digit reading the entire time that I used it.
Old Oct 17, 2007 | 05:46 PM
Ben D.'s Avatar
Ben D.
I read it as his engine didn't crank at all so my guess bad battery.
Old Oct 18, 2007 | 09:01 AM
NickBeek's Avatar
NickBeek
Drew is correct.... NC is a southern boy and "won't crank" means it wouldn't start in the south. We need a DF convention for this so us southerners can communicate better with yankees. Good thing I'm a transplant and can translate huh? [8D]
Old Oct 18, 2007 | 09:44 AM
Drew's Avatar
Drew
when us boys south of the mason dixon say she wont start it means the engine will turn. . .the starter works. . .she just wont fire up.
now when we say she's dead. . .thats when she wont turn over. I had to deal with that overseas with yanks trying to wrench on equipment. . .just aint gunna happen right
