Radiator swap
Old Oct 19, 2007 | 09:04 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default Radiator swap
well, todays been just great.
got to work ok this mornin.
walked out to fetch a tool and noticed the faint odor of antifreeze near the truck.
opened the hood and found that the left tank had slightly opened a seam at the upper rad hose. Ive seen the tell tale signs of it comin on.
needless to say, I found a NEW rad for this ol dog at $227 with tax. on the way home too
its in . trucks been idlin for 30 minutes or so to get the air out. will post a few picks of the new and old rads. just for reference.
btw Jimmy, ur rad is not avail after market yet..dealer only
Old Oct 20, 2007 | 09:13 AM
CowboyBob's Avatar
CowboyBob
Default RE: Radiator swap
Most radiator shops can replace that tank for around $75. I had mined replaced 2 years ago instead of buying a new radiator and it has worked fine ever since.
Old Oct 20, 2007 | 11:57 AM
Kev_n_AZ's Avatar
Kev_n_AZ
heck it took what? total time and goofin around , maybe an hour to pull the old, drop the new, connect the lines and start fillin it up with an idle off to check level.
Old Oct 20, 2007 | 03:44 PM
Kev_n_AZ's Avatar
Kev_n_AZ
here a pic of the old, and new rads.
the leak
the new
the location
another leak.....see the small heater hose at cyl #1...
Old Oct 20, 2007 | 09:17 PM
JimmyDiablo's Avatar
JimmyDiablo
that would have been a great time to change your spark plugs and muffler bearings. Did you get the high performance Radiator cap?
Old Oct 20, 2007 | 10:44 PM
Kev_n_AZ's Avatar
Kev_n_AZ
yea!
I got the last turbo rated radiator cap too!
Old Oct 21, 2007 | 12:07 AM
Mayfair's Avatar
Mayfair
Sucks, but at least it happened while you were at home instead of on the road. Glad to hear you got it all worked out. Thanks for the pics !!
Old Oct 21, 2007 | 02:06 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Thanks Mayfair
