B20 or ULTRA LOW??
RE: B20 or ULTRA LOW??
Are you kidding me??
B20! B20! B20! B20! B20! B20! B20! B20! B20!
I have been running it since the mid part of the summer. Even towed with gross weight 22,060 lbs. I have a Hypertech chip and leave it set on 3 all of the time. I started getting 21 MPG when I burned B20. LSD with Drew's Brew got me about 20 to 20.5. Regular LSD got me 18-19.5.
I get 11 MPG when towing the monster 22k rig, but only if I keep the speed right at or below 70MPH.
The B20 I am buying is 80% ULSD and 20% Bio. I bought 70 gallons last week and it was $2.89 a gallon with no cost of additives.
I have not had to change the filters because of the B20. When I dropped my tank last month for my dual pump project, the inside was clean enough to eat off of. So I guess I never had a dirty system to begin with. Just keep an eye on the FP gauge when you start using it and if you do see a drop in pressure, change the filter.
If better mileage, smoother running engines, cleaner emisions and keeping 20% of your money in the US isn't enought to get you to switch to B20, then maybe this will.
http://www.bloomberg.com/energy/
Oil hit $91 a barrel today, setting a new record. Show those oil companies that you have had enough!
Chris, I have run B20 on and off in my last three trucks including this one. I usually get the same or better mileage, and the engine is a lot quieter. It is FAR better at lubing the fuel system even at only 2%. The only concern you should have is it does gel at a higher temp. Being in the mountains and having a cooler climate you may get some gelling with out additives.
