Oil change for the first time
When prefilling the filter, don't forget to fill thru the small outer holes only. This procedure will filter the oil before it enters the engine. The large center hole is the filter oil outlet hole and if you prefil using it, you will allow unfiltered oil to enter your engine.
Don't forget to grease the tie rod end zerks and if a 4X4, the front driveshaft rear grease point using a needle.
ORIGINAL: w4phj
ORIGINAL: w4phj
ORIGINAL: FroneDaddy
That's what I use and have had no problems
ORIGINAL: DiEseLjunKy
You can forget those wrap around filter tools.They're worthless for these trucks there's no way to get your hands in there.
